18 Pages «<910111213>»
Caldercraft H.M.S Agamemnon Options
nightwisher
#201 Posted : 30 June 2015 23:10:01
So that's how you did it so fast BigGrin .If you know any gangs of riggers you can send them up the road to my sovereign.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#202 Posted : 01 July 2015 21:14:24
BigGrin Hi Nightwisher
Sending over drew,drew,barney mcgrew, cuthbert, dibble and grub have them for the week but there needed after that for caulking a brig.
#203 Posted : 05 July 2015 19:17:10
BigGrin Hi All
The rudder has been coppered and mounted using cast blocks as the hinges and the etch straps then holding the blocks in place, something close to how it was on the full size ship I suspect. After mounting the rudder it was time to start adding the side decorations this consists mostly of pre-cast shaped brass strip with two CNC cut walnut shaped rails, next it was the pre-cut hull stairway that was added, there are still two vertical rubbing strips to add here then its onto the other side of the hull to do the same. More soon.
#204 Posted : 05 July 2015 19:31:46
BigGrin Lovely work as always Andy looking great Cool
der Gohfelder
#205 Posted : 05 July 2015 20:04:23
Hi!
Some fantastic work is going on, superb stuff!!
Regards, Bernd
#206 Posted : 05 July 2015 21:28:19
BigGrin Thanks both of you for your comments and now a couple of pic's of the rubbing strips that have been added just the quarter gallery bling to go on this side now. now for the other side.
nightwisher
#207 Posted : 05 July 2015 22:00:09
Very nice,starting to see now why caldercraft kits are so expensive and sort after,especially in the right hands. Cool
#208 Posted : 05 July 2015 23:35:09
Thanks for your comments and looking in, they certainly are great kits, so much is pre-cut like the stairs on the hull they just needed a tidy up before fitting.
#209 Posted : 05 July 2015 23:56:36
Im in awe of your build Andy. You are making modelling look so easy.
Well done. BigGrin
#210 Posted : 06 July 2015 03:57:50
Brilliant work as usual Andy, she is coming together nicely Cool
#211 Posted : 06 July 2015 20:48:24
Hi looking superb there andy.certainly coming along at fair pace.look forward to more.cheers mick. BigGrin BigGrin
der Gohfelder
#212 Posted : 06 July 2015 21:04:51
Hi Andy!
Very nice and detailled work, well done as usual! ThumpUp
Regards, Bernd
#213 Posted : 06 July 2015 21:57:02
BigGrin Thanks every one for looking in and your kind wordsBlushing, there's still loads to do as the outer hull detail has only just started, the beakhead and gallerys will set her off perfectly when these and some paint are addedCool
#214 Posted : 06 July 2015 22:15:27
Andy,
This is just a great build to follow I know I have said it before, but when you watch a build grow like yours you become aware of the experience of the builder.
Trev.
#215 Posted : 08 July 2015 12:41:02
Hi Andy.
Realy comming on now. superp work being done on her.
Look forward to seeing your progress Ian.Cool BigGrin
#216 Posted : 08 July 2015 21:48:52
BigGrin Hi Trev
Thanks for looking in and your comments although I have always thought there are builders on the forum with skills far higher than my own but thats what makes this such a great forum as we can all learn from others to better our own skills.
#217 Posted : 08 July 2015 21:49:38
BigGrin Hi Ian
#218 Posted : 11 July 2015 20:37:38
BigGrin Hi All
The brass and wood sections have now been added to the other side of the hull along with the stair and rubbing strips, next its sorting out the stern quarter gallery's and the stern gallery with more brass strip,etch and castings. More soon.
#219 Posted : 12 July 2015 00:12:28
Looking fab Andy, always love to see the detail starting to be added to these ships and this one is no different.... Cool Cool .. Keep the posts coming...
#220 Posted : 12 July 2015 08:35:54
BigGrin Hi Alan
Thanks for looking in and your comments and I agree its when the detail is added that ships come to life. I have added a picture of the stern bling to give an idea of what is on there. The lemon yellow depicted is supposed to be close to how the Victory was painted around the time of Trafalgar I may mix white and yellow ochre at 1 to 1 to get a lighter yellow but we will see.
Guest (8)
This page was generated in 0.225 seconds.
