Andy, Hi well the hole build is beginning to take shape now, even more so if I had put the wings together as one piece but I am trying to put it off as long as I can not only due to the size but also the wait, and I have not panelled the under side yet, but a great model to build. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Lovely work Trev, looking the biz.... Regards Alan
Alan, Hi just read your post and thank you for your time, these reinforcements parts sometimes you think not more !! but after you have fitted a few metal plates your very glad that you have, and I must say that I have fitted more myself in the wing section all good fun. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE. PACK 22. 130615. Received today Pack 22 looks like lots to do there's wing plates, upper and lower, Fuselage plate, Engine plate, Engine support frets, upper wing fairings, Dashboard.  1 Upper wing fairing 4 2 Upper wing fairing 5 Stage 84.  Lower wing plate 17 18 19 23. Upper wing plate 10 Template. Looks to me as we have a plate missing (bottom )and the one at the top looks to big. Stage 86.  Fuselage plate 1. 2. 4. Engine plate 1.7. Template. Stage 87.  Engine support fret. Upper wing fairings 1.2. Paper Dashboard. UPDATE: AMENDMENT TO ISSUE 85. The wing plates that appear to be missing or the wrong shape will be supplied in future issues.  Apologies. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, once again I will look forward to seeing your progress when fitting the latest parts... good luck with it... Regards Alan
Hello Alan, Still working on Stage 21 but looking forward to stage 22. regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Regarding Stage 85, see the info in the official build for Stage 85 which notes as follows:"Note that the missing arrowed plate from the template (lower wing plate 20), is provided in Stage 101 and is fitted in Stage 102. (This also applies to the template/content of Stage 91)."The plate shape for the smallest plate is correct (lower wing plate 23) and the template has no bearing on this. But you appear to be missing the small squarish plate (top left) in your parts image photo (lower wing plate 18). Tomick attached the following image(s):
UPDATE:SPITFIRE. 270615. AILERONS.  First was to retrieve and identify ailerons left and right and the template to mark the aileron.    Using the template to transfer the lines onto the aileron plate with a scriber and ruler.  With the lines now transferred to the plate the next job was to glue to the fret, best to check that sides are aligned before gluing, you may find that you will have to sand to shape.    Test fit to the wing and adjust if necessary,should not be a tight fit. More soon Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
Sweet Job as always Trev really coming along nicely regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Starting to shine now Trev and nicely done Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Dan thanks for looking, the wings are starting to shape up now but as you know it all takes time as with your Zero build. Thanks Dan. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Awesoke job Trev, its looking great
Andy Thanks for your comments and for looking in,that shine has caused problems with the pictures. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Davetwin, Good to hear from you and thanks for your comments, more to follow. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE. 270615. ENGINE SUPPORT. Engine support has three sides to glue together, after removing fret and sanding down then dry fitting, making sure that when positioned in the fuselage it fits correctly (note Mr T Build) you will see that the sides will splay out, this is how I have fitted my engine support to my Spitfire as you can see from my pictures, not much more to say on this bit other than thanks for looking.      Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Beautiful work Trev, the iconic shape of the wing is really there to see now...  . Loving the build... Regards Alan
Alan, Thanks for looking in, the next part will be airbrushing the wheel arches and fitting the undercarriage. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE. 030715. SPRAYING UNDERSIDE OF WING. This involves masking of the area where the undercarriage will be fitted, first to primer then final coat using XF76.  Mask of area.  Then I sprayed with Tam Grey Primer.  My final coat Tam XF76. Next I will show you how I fitted the undercarriage. Kind Regards, Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nice update Trev, looking good. Steve
Nice one Trev, I am really enjoying your build
