Joined: 02/03/2015 Posts: 84 Points: 245 Location: England
Ok guys sorry to make a new thread for this simple problem! Ive been looking at the tyre template from museum.. Museum templateBut im struggling to work out if its suitable (correct size) for the MP4/4... Any info much appreciated! EDIT: Autograph not museum! Building the MP4/4!
 Hi Phil The correct template for the wheels is supplied with the Autograph MP 4-4 Front Wing Set, but be careful with it as its quite thin. Hope this helps, link below, http://shop.autographmod...en-MP4-4-1/8-front-wing
Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Ah thanks for that! How strange that the template doesn't with the tire scripting decals. I have some tamiya primer, do you reckon that would bond properly onto the tire? Building the MP4/4!
Joined: 01/12/2014 Posts: 102 Points: 312 Location: Chicago, IL
Phil wrote:Ah thanks for that! How strange that the template doesn't with the tire scripting decals. I have some tamiya primer, do you reckon that would bond properly onto the tire? Phil,
See the pics in my build thread, I used the Museum template on the tires. I don't see why the Tamiya primer wouldn't work. I used GSI Mr. Color white on my tires and applied 3 coats.
Ah yes I remember yours well, they came out great! I Will get the decals and give it a go. Thanks everyone for the help. Building the MP4/4!
