5 Pages 123>»
Graeme's Akagi build Options
#1 Posted : 04 June 2015 11:28:19
Hi all, well I've taken the plunge as my SOTS subscription ends this month I have ordered up the Akagi and got the first dispatch at £1.
I will start the diary once I receive the first months issues.
In the mean time I will be reading through the other diaries on here and deciding if I will be making any mods along the way.
#2 Posted : 04 June 2015 11:53:39
hi graeme look forward to your build as i`m about to start mine will follow with interestBigGrin
#3 Posted : 04 June 2015 14:04:44
Hi Graeme
I did the same as you and took advantage of the £1 offer for the first pack, which arrived just before I went away on Holiday.
I was really impressed with the parts included, it even includes sand paper, glue, paint brushes and needle file BigGrin
Look forward to seeing your diary Cool
#4 Posted : 24 June 2015 11:05:17
I received my first pack on Friday and am impressed with the parts. After reading the other diaries on here I have decided to leave starting the build until I have all the hull frame parts ( unless I get tempted by the aircraft) so I can build the frame in one go screwed down to my build board.
#5 Posted : 24 June 2015 12:13:10
Hi Graeme.
Look forward to seeing your progress IanBigGrin
#6 Posted : 24 June 2015 17:42:01
BigGrin Will look forward to your buildCool
DSoldano
#7 Posted : 30 June 2015 21:32:45
Graeme,
Looking forward to the build. This one is on my list, in fact, I almost ordered this before I ordered HMS Victory. Hopefully it will still be available when I complete Victory.
Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon
Up Next: We'll See
#8 Posted : 01 July 2015 09:08:13
Hi Graeme, BigGrin
Great looking kit and good luck with the build.
Look forward to seeing your diary.Cool
#9 Posted : 01 July 2015 10:54:26
Looking Forward to your diary, Graeme!
#10 Posted : 13 August 2015 22:48:19
I have now received pack 3 of the build. I have decided to wait for pack 4 before starting the actual build.
There are 2 reasons for this, one is it will mean I have all the parts up to starting the planking and the second (and more important one)is that my son will be back at Uni by then so I will have room to set up the building board.
#11 Posted : 12 September 2015 17:02:04
I have now received pack 4 and started the build Laugh .
Pic 1 shows the build board set up with a centre line and covered with polythene to prevent the base plates from sticking to the board.
Pic 2 shows the parts received to date still in their packing. I will be leaving all the metal parts in their packing until they need in the build.
Pic 3 shows all the frame parts laid out.
Pic 4 is of all the frame parts dry fitted.
At this point I positioned the hull along the centre line of the board, drilled pilot holes in the base plates and screwed them to the board.
Pic 5 shows this.
I then removed all the frame parts, Pic 6 and then unscrewed forward of the 2 centre base plates,removed it, applied glue to the forward end and then replaced it and screwed it back down. I then repeated the process with the aft centre plate but applied glue to both ends before screwing back down, pic 7.
i am leaving the base plates to dry overnight before gluing all the frames back in place.
#12 Posted : 12 September 2015 17:39:32
Great start Graeme, I love this one so will be watching closely Cool
#13 Posted : 12 September 2015 18:49:01
BigGrin Nice start GraemeCool
#14 Posted : 13 September 2015 00:18:42
Great to see you get started with this fab kit Graeme, I'll be following your progress over the coming weeks and months.... Good luck with the build....Cool Cool
#15 Posted : 13 September 2015 11:15:02
Congrat's on your first medal Cool
#16 Posted : 13 September 2015 18:15:31
nice start graeme BigGrin
#17 Posted : 13 September 2015 18:56:38
BigGrin Very nice start Graeme looking forward to seeing more Cool
#18 Posted : 13 September 2015 19:00:52
#19 Posted : 14 September 2015 11:17:11
Thanks for all the comments guys, and the first medal.
Just a brief update. I have glued all the frames up to 26 in place and I am going to let them dry completely before adding frames 27 on asI will have to remove the bow screw and the 2 stern screws before I can fit them.
Frames 24-26 at the stern were setup using an engineers square then held in place with a couple of machined steel blocks while the glue dried.
#20 Posted : 15 September 2015 08:04:13
Good start, Graeme!
Guest (5)
5 Pages 123>»
