 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
very smart magpie, the symmetry is spot on.
Joined: 25/01/2010 Posts: 459 Points: 1,367 Location: Bridlington
Yep I did but bad happens lol  no biggy though. Regards
Rob
Bridlington.
Built Flying Scotsman (Train). Collecting HMS VICTORY
Hi All, Here is the first side sanded down ready for the Gunport cutouts.
Thanks Chris..
magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 23/04/2010 Posts: 84 Points: 234 Location: Redruth
Very nice planking that! Built Billings Le Bayard Mamoli Golden Hind Corel Shenandoah In Progress AL King of the Mississippi Mantua HMY Britannia 1893/HMS Victory 1/98 Stopped Yet to start AL Zuiderzee Botter (Pre laser)Fun fun fun Constructo HMS Victory Caldercraft HMS Victory Deag HMS Victory
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
Looks as smooth as a babies nether regions!Nice job,wife has been commenting on how nice it looks....don't want to get my hopes up but it will soon be birthday & christmas time(couple of days apart!) Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
Thanks for your comments, :)
Here I have gone off course of the instructions.I had installed the inner walls as you can see and painted them whit but then decided to bash up some more..lol. I have cut my first gun-port and marked the others. I have used an image of the original plans of the surprise to get the ports in the correct position which is where the Jotika ports are placed.
I also changed the method of doing the gun-ports. Here is a picture of how it is done A/L's way. Then Pictures of how I have done mine.
Chris magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 wot do u mean giving up the Vic  who's next Tomick????(it'l be bad enough if he takes a holiday over the next 2 years)  capt stedders not going to be amused  no sparing partner  seriously though i think a lot of regular forum members will be dissapointed as your contribtions have been top notch even if u do support the Norwich Union Football Club
Thanks for you comments
I will be on here all the time, The wife says all I do is sit at the computer.lol I even have the forum saved on my Iphone..lol... With cash wearing thin at the moment it had to be the Victory to take the blunt of it.. But I will try to build it. Just need parts listings etc.
I will be giving input to you all if you need any that is...
Thanks Chris.On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Now, that is a good looking build there magpie, very nice in deed...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Thanks For the comments. :)
Here is one of the Stern Gunports. The last three have port doors as that is were the admirals cabins are.(Whatever they are called). This is my interpretation of those.
Chrismagpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi All, Here is the bow Gunport. It is further forward than the Instructions say.. It is in-line with the prototype Gunport.It was quite tricky as the front is solid and I will have to use a dummy cannon.
Chris.magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi magpie if you shoot a cannon from your forward gun port you will blow you're head and catwalk off Regards
Rob
Bridlington.
Thanks for your Concern M8.
I've tried to study the pictures of the original HMS Surprise and from the original Plans of the ship it has a port there from which I have been informed is called a Bridle Port? What it was used for I don't know. The Surprise had 24x 32Lb Carronades on the main Deck which works inline with that one being whatever a Bridle Port is. Here is a Picture of the Protype of the Jotika Surprise which has used the same plans. I will have to scratch build the Cathead though.
Cheers Chris... On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hello all. Here I have managed to do all the ports on one side and line the inside of the main deck.
Chris...magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Stands back in admiration...Looking great magpie, keep the pictures coming...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Guest (5)
