18 Pages «<678910>»
Caldercraft H.M.S Agamemnon Options
#141 Posted : 15 June 2015 09:10:16
BigGrin Hi Alan
Thanks for looking in and your comments as for the tiles I will be going for the aged look using 'Patina-it' Steve used this on the hull of his Victory and has mentioned the other product they do called 'weather-it' for wood.
#142 Posted : 15 June 2015 13:32:19
looking good, and getting through it quickly Cool
#143 Posted : 15 June 2015 21:53:31
Looking Great Andy, you've made good headway in your build, its looking awesome todate.
#144 Posted : 15 June 2015 22:51:39
BigGrin Thanks both for looking in and your commentsCool
#145 Posted : 16 June 2015 23:55:02
BigGrin Hi All
The tiling proceeds at a steady pace in fact im quite enjoying the process of seeing it build up on the hull, a few pics on progress.
#146 Posted : 17 June 2015 00:10:41
#147 Posted : 17 June 2015 08:00:23
That tiling does look very nice indeed Cool
#148 Posted : 17 June 2015 08:24:42
BigGrin Thanks everyone for looking in and your commentsCool
#149 Posted : 17 June 2015 12:01:29
Hi Andy great progress on the tiles.I found this job on me victory very relaxing in fact.I used the same tiles they do look good.just found ya do have to check for double tiles as eh do like to stick together on the rivets.going great and look forward to more.cheers mick.BigGrin BigGrin
#150 Posted : 17 June 2015 22:52:37
BigGrin Hi Mick
Thanks for looking in and your comments and I agree about the tiling ,had a few doubles but managed to spot them all bar one so far and yes very theraputic.
Gibbo
#151 Posted : 17 June 2015 23:17:51
Looking really good Andy, following this one all the way.
Paul
#152 Posted : 18 June 2015 12:52:09
Hi Andy.
Copppering looks great so far. how are you finding sticking the tiles on.
Ian Cool BigGrin
#153 Posted : 18 June 2015 19:56:56
BigGrin Hi Paul and Ian
Thanks for your comments and looking in.
Im finding the tiling quite theraputic although you have also to think as the lie of the hull can be challenging in parts.
#154 Posted : 18 June 2015 20:01:59
BigGrin Hi All
The turned brass wheel's arrived today there in kit form but very nicley made. The axle on one will have to be removed to make the matching pair but there a marked improvement on the kit ones I think.
#155 Posted : 18 June 2015 22:33:09
The difference between the two is like night and day, without a doubt a vast improvement Cool
#156 Posted : 18 June 2015 23:52:25
Great work on the build Andy. The rurned brass wheels are a massive upgrade from the original ones.
#157 Posted : 19 June 2015 22:48:09
BigGrin I have to agree with you both and thanks for looking inCool
#158 Posted : 19 June 2015 23:06:51
BigGrin Hi All
Copper sheathing continues, when I started the sheathing I suspected that the plates were applied in certain ways such as when they were first used until later. The sheathing was firstly applied to the bottom of the stern post and keel and then worked forwards untill the hull was covered. The earlyest form of sheathing was the smiley face type where the shape of the hull caused the tiles to slope upwards at the bow and stern the plates were then capped with a straight run of plates, a wooden baton running along the top with the plates trimmed to the baton or simply a rolled up piece of canvas nailed in place.
As time passed the copper plates were replaced by 'Muntz' metal an alloy of 60% copper and 40% zinc sometimes called Yellow metal. The tiling also was laid in straight lines a perfect example of the use of Muntz metal and straight tiling patterns is the newly refurbished Cutty Sark at Grenwich.
More soon,
Regards.
#159 Posted : 19 June 2015 23:41:34
Great job with the tiles Andy. Starting to look the part now.
Gibbo
#160 Posted : 20 June 2015 00:53:44
Well that's certainly looking the business Andy
Pau;l
18 Pages «<678910>»
This page was generated in 0.204 seconds.
