6 Pages «<3456>
Gun Ports..a disscusion Options
jonny7england
#81 Posted : 12 September 2010 10:30:07
Whoooops!!!, well spotted on that one Colin, like you, I have used filler in the bow section, only balsa, but me thinks a bit of butchery to my loving workmanship is needed here to make way for that cannon port...LOL Thanks for pointing that one out Colin...ThumpUp
Zeptrader
#82 Posted : 12 September 2010 10:47:18
I don't think its a major problem even if you haven't used balsa, looking at some pictures it could well be a closed hatch, so maybe ok.
#83 Posted : 12 September 2010 11:06:48
I'm pretty certain that the two bow ports will have closed doors.
jonny7england
#84 Posted : 12 September 2010 11:15:18
Thanks for that Tomick, I will put a hold on any alterations until further into the build...John wipes the sweat from his brow...phew!!...LOL
jumbo
#85 Posted : 15 September 2010 21:49:41
bit dissapointed with timber supplied for planking as i will be varnishing my model.clearly shows diffirent model on front of magazine.Tomick is doing a good job
but line of gun ports differ from model shown.I have had to send to cornwall models for walnut planking.worried about the line of plamking for future build.hope you all understand what I am talking about.Hope this can be sorted out soon as the cost to the build increases.Good building Jumbo.
#86 Posted : 17 September 2010 20:13:24
Hi All,
Here is how I am planing on doing my Gun ports. I will cut the holes 13mm instead of 12mm then using 1x6mm lime strip will line the inside of the gunport with 1mm over hanging the front. Gluing with thick super glue. Then sanding flush with the front. Here is the result. (the real victory seems to not have a lip on the gunport so I haven't added one.
Jack Sparrow
#87 Posted : 17 September 2010 20:29:10
I found a pick that shows the gunports have a recess allowing the covers to fit flush in the hull as a sort of seal. Might be wrong and this is how its done now not then!!BigGrin BigGrin
Lonestar Spirit
#88 Posted : 17 September 2010 20:34:13
I'm hoping to create the recess, there is something about it that looks so right, but then again, it could also be so wrong, but that's what I will be doing.
Ship Builds on the go
Zeptrader
#89 Posted : 17 September 2010 20:47:50
That mock up looks really good, well done for that, I've looked over quite a few models and it seems it down to personal choice. Some have them some don't, if you feel happy to bash it a little then go for it, I don't think anyway will be wrong, historical accuracy aside its more of a representation of the Victory and your mate and family wont be picking holes in it.
I'm still undecided as to what to do, but this part of the build has to be as perfect as we can get, no changes later on..arghhh!!!
So time spent doing mock up's and chucking ideas around is time well spent.
I'll hopefully will get back in the tin shed this weekend and may even mock up an idea or two. But I will be going down the route of a recess/lip of sorts, I think it only needs to be no more than 1mm, at least to keep scale in mind.
As the wood planking is a massive 2mm any ideas of framing first would create a too bigger recess for the scale of the ship.
willz
#90 Posted : 17 September 2010 20:48:45
That is correct Jack Sparrow, the only ones to my knowledge without the rabbit are the ones without gun port lids
Jack Sparrow
#91 Posted : 17 September 2010 20:54:06
This where double plank would help!!! BigGrin BigGrin
#92 Posted : 17 September 2010 21:18:23
Sorry guys this is the pic I looked at for the ports... Which shows none but looking better its bad lighting.... Ah well I will make a new mock up now....lol
andylangtree
#93 Posted : 17 September 2010 21:32:54
Does this pic help for the gun port rabbets or whatever there called
#94 Posted : 17 September 2010 22:09:17
Well.........
Here is Mk2 of my gunport. I used 0.5mm strip this time. and double lined it.
Chris....
#95 Posted : 18 September 2010 00:01:36
my concern with the recess is having to do it from the front with no access from behind the gun port. double planking still seems the best way but i don't want to do that. I will play with some of the extra planking I now haveBigGrin
#96 Posted : 18 September 2010 00:04:10
Hi Jase,
I tried to do this in a way that I could do it without getting it from behind.
I managed without any problems doing it all from the front.
Chris...
Jack Sparrow
#97 Posted : 18 September 2010 00:09:19
magpie1832 wrote:
Well.........
Chris....
Now thats just showing off!!!LOL Flapper LOL I bow down to you sir that is a wizard idea!!!Drool Cool BigGrin BigGrin
One eye
#98 Posted : 18 September 2010 09:48:14
Rank: Amateur level 2
Hi All
An intresting topic, this one.
Zeptrader. Brilliant input on the framing aspect. I like the idea, and seen no problems with sufficient room between the planking, and the barrel supports. I realise that the framing would need to be parallel to the deck, which is something which could be lost or miss positioned by using the lining only method. Very accurate work indeed.
Magpie. Your Mk2 looks the dog's dangly bits. Probably a lot more work as well, but I think it would be well worth it. By the way, thanks for your 'Build' links. Fantastic work indeed.
I have a way to go before I get to this stage, but previously found that cutting out 100 plus gun ports and then having to line them was tedious, but it is one of the most important aspects for a great finish. One out of line stands out like a saw thumb. I may sit on my hands for a while and see how you lads progress, then decide later.
A final point which I wouldn't mind some feedback on. Has anyone considered that the thickness on Victory's hull vary's from about 24" at the lower gun deck to 18" on the upper and quarter decks. Is it being too perfectionist to make allowance for this when lining the Gun Ports? My dimensions are only educated guesses, as I dont have scaled drawings (I checked as best I could through the 'Anatomy of the Victory' book). The difference scaled down would be approx 5 to 6mm linings up top, with 7mm lining at Lower Deck level. I will be painting the linings Red, and feel this may be noticable - perhaps not so much if doing the natural finish.
See ya.Wink
PS. Also, does anyone realise that Victory had three types of 12lb canons (Long, Medium and Short), and that the two 'Short' ones one the Forecastle are actually 8' long as opposed to the other two types, which were 9' long. OhMyGod
Zeptrader
#99 Posted : 18 September 2010 10:02:09
Hi OneEye
Regarding the varying thickness I think it was mentioned here, the lower deck was around 5mm then going up the hull to 4mm then 3mm, your measurement maybe correct being 7, 6 and 5mm from lower deck upwards seems about right as well.
One fact remains solid is they will need to be a little difference as we progress with gun ports up the hull.
As the pictures shows the sills would be made first with the use of a batten to gauge the correct position in line with the lower deck.
Then a jig of sorts could be made to the correct size being cut and placed whilst adding the lintels, thus getting the correct height and following the angle of the deck.
Sounds OK in talking the talk, BUT as with many things putting it in to practice is another world, especially if you've never done this before, like me for a start, that's why making a small mock up comes in handy, to see any pitfalls.
I think what ever way is decided by the individual needs time and patience and I just know with all the discussion here we will come up with whatever method suits his or hers capabilities, and be a winner.
Zeptrader
#100 Posted : 18 September 2010 17:50:48
Ive completed my little mock up here - using the framing method.
http://forum.model-space...s&m=16197#post16197
Not as easy as it seems, and we have to do how many gun ports??
6 Pages «<3456>
This page was generated in 0.773 seconds.
