8 Pages <12345>»
Graham's CB750 Build Options
#41 Posted : 08 June 2015 11:10:51
Looking good Graham Cool
#42 Posted : 08 June 2015 16:35:24
Coming along nicely Graham Cool
Black Shadow
#43 Posted : 29 June 2015 17:41:21
Rank: Beginner Level 3
Hi Graham, like the other builds on here, I have been looking through your diary and like the other guys, you are making good progress. I am new on here and decided to go for the Fat Boy, but have since changed my mind and ordered the Honda CB750 instead. Plus, my wife prefers the Honda to the Harley, so I am just waiting for the first parts to arrive. Once I receive them I will start my own build log.
Geoff
Built : Robbe 1/40 scale Type XX1 Radio Controled : Scratch built 1/48 scale Ton Class Minesweeper Radio Contolled : Caldercraft (Jotika) Bomb Vessel Grando display model.
Building : Hachette Part Works U96.
To Build : DeAgostini 1/4 Honda CB750 : Tamiya 1/6 Harley Davidson Super Glide : Tamiya 1/12 1967 Lotus 49 F1 Racing Car : Revel 1/24 Shelby Cobra : Revel 1/24 Ferrari 250 SP GTO
bugsec
#44 Posted : 30 September 2015 10:03:46
Well it's been a while since I updated this build but it has still being going on.
Pack 7 has Stages 21-24 but 22-24 are parts only with no build.
bugsec attached the following image(s):
bugsec
#45 Posted : 30 September 2015 12:50:25
Pack 8 contains Stages 25-27
Stage 25 is the air filter case and the stage finishes with a test fitting of the carburettor.
bugsec
#46 Posted : 30 September 2015 12:52:17
Stage 26 is the rear tyre and fitting it to the wheel supplied at Stage 24.
bugsec
#47 Posted : 30 September 2015 12:53:36
Stage 27 is the final sprocket drive and is a parts only stage.
bugsec
#48 Posted : 30 September 2015 13:43:45
Pack 9 contains Stages 28-30
Stage 28 has the rear brake panel and rear brake stopper arm. Also needed are the rear wheel and tyre from Stage 26
bugsec
#49 Posted : 30 September 2015 13:46:37
Stage 29 has the swingarm, rear wheel axle and nut. Also required are the drive sprocket from Stage 27 and rear wheel from Stage 28
bugsec
#50 Posted : 30 September 2015 13:48:39
Stage 30 has the drive chain. No build at this stage just a check that things move properly.
bugsec
#51 Posted : 30 September 2015 14:28:06
Pack 10 is Stages 31-33
Stage 31 contains the chain cover and stickers for the shock absorbers. Also required are the swingarm from Stage 30 and shock absorbers from Stages 32 and 33.
bugsec
#52 Posted : 30 September 2015 14:32:41
Stage 32 contains the right frame half, a washer and two different types of screws. There's no build at this stage.
bugsec
#53 Posted : 30 September 2015 14:37:30
Stage 33 is the rear brake. Parts included are the assembled brake arm, brake pedal, brake pedal spring, fork pivot shaft, spring holder, a washer, a nut and two types of screws. Also required are the swingarm and wheel from Stage 31 and the right frame half from Stage 32.
bugsec
#54 Posted : 30 September 2015 14:47:13
Pack 11 has Stages 34-37. Stage 34 is the rear fender. Parts included are the rear fender A, rear fender B, wire holders and three types of screws.
bugsec
#55 Posted : 30 September 2015 14:50:13
Stage 35 is the tail light. Parts included are tail light, licence plate bracket, licence plate, licence plate back plate, nuts and two types of screws. Also required are the rear fender and previously supplied screws.
bugsec
#56 Posted : 30 September 2015 14:51:47
Stage 36 is the rear right indicator. Parts included are rear right indicator. Also required is the right frame half from Stage 33.
bugsec
#57 Posted : 30 September 2015 14:54:03
Stage 37 is the centre stand. Parts supplied are centre stand, centre stand spring and screws.
bugsec
#58 Posted : 30 September 2015 14:59:38
Pack 12 (half way) contains Stages 38-40.
Stage 38 is the right crankcase half. Parts supplied are the right crankcase half, points cover , screws and a long Philips screwdriver.
bugsec
#59 Posted : 30 September 2015 15:01:35
Stage 39 is the IR sensor board. Parts supplied are oil pan, IR sensor board, IR sensor window and screws.
bugsec
#60 Posted : 30 September 2015 15:04:57
Stage 40 is the left crankcase half. Parts supplied are the left crankcase half, cord grommet, starter cover, wire cables and screws. Also required are right crankcase half (Stage 38), oil pan, IR sensor window and screws (Stage 39).
8 Pages <12345>»
This page was generated in 0.331 seconds.
