Gold leaf? Options
aurelius
#1 Posted : 07 June 2015 11:21:28
Hi there,
I have just finished applying the sapele strips to the upper hull and cut out the gun ports. I am quite pleased with the result so far. I am getting to the stage of applying the guiltwork decoration and have purchased a goldleaf kit from an art shop. Does anyone have any experience of applying gold leaf to the decorative castings. Questions which occur to me are;
Do you still prime them?
Would a gold painted undercoat before you apply the leaf to disguise any tears be too obvious? The sheets are so thin that they blow away with the slightest puff of air.
I can see that covering some of the smaller castings is going to be a bit tricky. Getting a clean cut around the edges is going to involve some delicate work with a scalpel and magnifying glass.
Any other pitfalls which you can see?
I just think it would add a bit of 'authenticity' and may be worth going to the extra trouble to achieve especially as the subject is the SoS.
#2 Posted : 07 June 2015 11:41:05
Hi Aurelius, great to hear from you and also happy to hear your SOTS build is progressing nicely.. I personally haven't worked with Gold Leaf but there are members here who have, perhaps they would be better placed to give you the answers you seek.... Cool Cool .. They have also posted on this subject, if you use the search facility on this forum and type in the key words 'Gold Leaf', this will bring up a number of posts that may be of assistance to you....Cool Cool .. Good luck with the task and hope the rest of your build is a success...
aurelius
#3 Posted : 09 June 2015 02:59:35
Thanks for your reply Gandale.
I tried the only search box I could find and typed in the key words but no results.
Do you have any links?
Thanks
Aurelius
#4 Posted : 09 June 2015 07:27:28
Thanks
Aurelius
Hi Aurelius, if you look near the top right of your screen, near the login icon you will see the word 'Search'. Click on that and it will open up a search selection screen. Will see if I can get someone to answer your query....
#5 Posted : 09 June 2015 07:44:06
BigGrin Hi Aurelius. delboy 271155 has used gold leaf on his SOTS if you look up his build diaries you can see how he did it ThumpUp Hope this helps rgd Martyn
aurelius
#6 Posted : 10 June 2015 02:57:55
Thanks Martyn,
delboy 271155 has been in contact and I will check out his build diary
cheers
Aurelius
