I also used a Rotary cutting tool to shape the ends but that may be a bit over the top. Cutting Tool
 Rank: Pro  Groups: Registered
Joined: 25/04/2015 Posts: 154 Points: 462 Location: Northern California, USA
John, Those look fantastic - I may save that for the next build but I'll definitely try it at some point. Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon Up Next: We'll See
Hi Dominick. Great job on your barrel stack. loolk forward to seeing your progress I  an. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Top job on the Launch looking good jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Jase and Ian, Thanks – more coming very soon. Dominick
Barrel Stack complete. I added some bungs to the barrels using bits of toothpick (cocktail sticks in the UK) as suggested by John - great idea. It's not perfect but I like it. DSoldano attached the following image(s): Dominick
They look perfect to me Dominick. You've done great work on the Vic she's gonna be beauty when done. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 30/04/2015 Posts: 75 Points: 234 Location: St. Louis USA
Dig what I am reading and seeing. I really like John's idea. Well executed D. In the workshop: HMS VictoryFinished builds: Providence Whaleboat
 Top work and looks great Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Lovely work on those barrels Dominick Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Gents, Thanks for the kind words. I'm glad everyone is enjoying it. I plan to assemble the framework for the hull this weekend - I soaked and weighted the frames and most of them came out very flat. One still has the slightest bit of warp but it should straighten right out when the false decks are installed. I'll take and post progress photos as it comes together - one of my goals of doing the build log is to help other beginners that might come after me. Dominick
I'm a beginner. That would be for me! I'm going to get the HMS Victory soon. [quote=DSoldano]Gents, Thanks for the kind words. I'm glad everyone is enjoying it. I plan to assemble the framework for the hull this weekend - I soaked and weighted the frames and most of them came out very flat. One still has the slightest bit of warp but it should straighten right out when the false decks are installed. I'll take and post progress photos as it comes together - one of my goals of doing the build log is to help other beginners that might come after me. [/ In the workshop: HMS VictoryFinished builds: Providence Whaleboat
Gauncer, Great - hope my posts help. Dominick
I have a question for the larger group. In assembling the framework for the hull this weekend, I will have to decide whether to include or exclude the cutaway. I'm kind of torn on which way to go. Anyone care to put forward the pros and cons of the cutaway and/or no cutaway? Dominick
DSoldano wrote:I have a question for the larger group. In assembling the framework for the hull this weekend, I will have to decide whether to include or exclude the cutaway. I'm kind of torn on which way to go. Anyone care to put forward the pros and cons of the cutaway and/or no cutaway?
Hi Dominick, believe you need to think of how and where you want the final build to be displayed. The cut out section will certainly be full of detail and gives a great insight as to the cramped conditions the sailors had to endure... This one is all down to personal choice, me I would probably go for the cut out section.... Regards Alan
Hi Dominick. I Personaly like the cutaway section veiw. as Alan said it is also which way you want to display the model. Also if you are coppertilimg i would do the oposite to which you are displaying first because i found the second side easier as you are used to doing the tiles. Hope this helps Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Alan, Ian, Thanks for the input. I am leaning toward the cutout but I guess I still have a few days to decide. I am planning to build a free standing case, perhaps with bar storage on the bottom, that will go against a wall. I suppose I can always turn the ship around in the case if I prefer one side or the other. Dominick
I just hit a major milestone. Today I assembled the frames to the keel and fit the main gun deck to the rest of the framework. I had to take a good bit of warp out of the stern deck halves but a light soak and a day or two under some heavy books and most of it was gone. The center of the two deck halves goes exactly down the center of the keel and I centered all of the frames to my lines. I thought I would post the pictures before I glue it up. I'm a little embarrassed  that I actually drove the nailer through the deck in a few places (see picture 3). My assumption is that this deck is completely hidden and that I don't need to patch and fill the holes or worry about any of the nail heads  . Someone please correct me if I'm wrong. There are also a few spots where the deck sits out slightly from the frames and where the frames sit out slightly from the deck  (see pictures 4 and 5). My assumption is that all of this will get corrected during the fairing process. Again, someone please correct me if I'm wrong. DSoldano attached the following image(s): Dominick
Looking good Dominick and you are correct on both counts, you will not see any of the deck you've just laid so appearances here don't matter, what matters is that the deck is correctly fitted and all lined up...  .. The fairing process will take care of any deck overhang from the ribs so again no need for concern here.... Regards Alan
 Now that looks like a hull ready for planking and as Alan says any overhangs will be removed with the fairing process. Are you going to put infills at the bow and stern to aid in the laying of the planks, as for the cut out have you seen how Bernd did his cut away section if you do take the cutaway route then some planing at this stage of the build will pay dividends if you choose to do something along those lines.Look at pages 12/13 of the build link below. http://forum.model-space...sts&t=4698&p=12
Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (8)
