6 Pages <12345>»
My Jupiter Build Options
GilShapley
#41 Posted : 02 June 2015 16:32:14
Have now added the skins to the timber frame of the boiler
Used Evo stik express on one part but found this too thick and the part almost ended up becoming a part of me.
Reverted to the good old super glue gel with more success
Used some pins to hold the skin in place whist the glue went off. They will not show on the final model so will leave them in situ
Next step is to glue the parts of the boiler together and fill in where necessary, sand and then paint
Will use some Perfect Plastic Putty as recommended by my local model store. according the the blurb on the box it "Fills fine gaps, Creates invisible seams"
We shall see
Picture attached
Current Build:-
GilShapley
#42 Posted : 02 June 2015 16:39:07
The Bridge I have built to display this model is some 900 mm long, the train will be 503mm approx so this leaves me some 400mm to play with.
Am thinking of adding a freight wagon (310mm) to complete the display
Did look at the Coche Costa Coach but it would be to long.
Will need to confirm that is is suitable for the G gauge track dimensions before I decide
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
#43 Posted : 03 June 2015 16:47:38
Hey Gil,
I found this video on youtube of the Jupiter replica.The front door is open and you can see the interior cab color is a dark green.
I think I will try to match that for my Jupiter
https://www.youtube.com/watch?v=p8vIX1JLV_s
GilShapley
#44 Posted : 03 June 2015 18:16:15
Hi Carl
Thanks for that link will watch it tonight. I have already decided to go for a darker green than that shown in the build instruction which is more of a lime
Yuk
Have you started on the front of the boiler yet. The hinge on the right of the "door" in my parts was too short so I removed the ends and added a length of brass rod. Once painted you will not notice my "upgrade"
Picture attached
Have a nice day
Gil
Laugh Laugh Laugh
Current Build:-
kpnuts
#45 Posted : 08 June 2015 08:12:52
I can't see any of the last lot of pics on my playbook, is it me or are you using another method to post pics? Enjoying watching the two different building methods.
GilShapley
#46 Posted : 08 June 2015 09:33:12
I have had the same problem when viewing other builds
Instead of a picture all I see is a small box where the photo should be.
I am using Google Chrome so that may be the problem
If you "right click" on the small icon and select reload from the drop-down menu the pictures should appear.
You can also try CTRL and R which has the same effect
Confused Confused Confused Confused Confused Confused
Current Build:-
GilShapley
#47 Posted : 08 June 2015 09:55:49
have now painted the Boiler using the satin finish and not the flat black recommended as i prefer the look
A steady hand was needed to paint the number and surround
Have started work on the interior of the cab LOTS of small parts to fit and paint
Should be fun !!!!!!
Still plenty of work on the boiler which will continue when the paint is dry
Current Build:-
GilShapley
#48 Posted : 08 June 2015 10:46:58
For some reason the picture of the boiler did not attatch so here it is
Current Build:-
#49 Posted : 08 June 2015 11:31:12
Wow Gil, I love the look of this, you are doing a fantastic job with it and especially love the trestle you have built to display it on BigGrin
#50 Posted : 08 June 2015 16:13:00
That is looking fabulous Gil.
GilShapley
#51 Posted : 08 June 2015 16:37:17
Thanks for the comments everyone
Blushing Blushing Blushing Blushing
Carl I still have a bit to go to catch you up but "its not a race but a journey"
Laugh Laugh Laugh Laugh Laugh Laugh
Have built the framework for the tender but have yet to cover it
Spending time on the controls for the cab interior.
Still not 100% on what colours (colors) to use whether to go for the suggested colours (colors) or not
Have seen a picture on the web of an interior for the cab which shows the wood varnished and not painted, but this would mean I would have to line the interior with timber strips to match the exterior.
Current Build:-
#52 Posted : 08 June 2015 17:25:20
Hmm what to do with the interior?
The video by O`Connor said the cab was left unfinished because it was so beautifully made, but then in the video I found from promenatory point the same train? has a green painted interior.
I did find out that originally at the Golden spike re-enactment the Jupiter train was actually a gas powered replica.THis was replaced by the one that O Connor built in the late 70s so I am not sure which train I am looking at on youtube.
I think I am going to paint rather than use wood.
GilShapley
#53 Posted : 12 June 2015 19:47:02
been busy painting the interior cab components
Items required :-
Paint - Gold-Silver-Red-Black
Brushes - various sizes
Patience - Large quantities
Ear plugs for the wife
Still when all said and done am happy with the results so far, all I have to do now is fit them to the cab which is the next job once the cab has been painted
Current Build:-
#54 Posted : 12 June 2015 20:02:22
Looks great Gil
GilShapley
#55 Posted : 13 June 2015 16:13:14
The next step for the boiler construction is to add the brass bands that go around the boiler
Provided are a number of brass strips which need to be bent to fit around the cylinder of the boiler
My first attempt using long round nose pliers was poor resulting in too many kinks in the brass.
Thinking cap on ????, My son is a plumber and had numerous copper fittings which he uses in the course of his work.
A quick look at what is in the shed I found a fitting used to reduce 22mm pipe to 15mm. Putting this on the end on my finger (bit like a thimble) I worked the brass strip around the large end first then the smaller end resulting in a length of brass the required shape to fit the boiler and no kinks
Jobs a goodun
Current Build:-
#56 Posted : 13 June 2015 16:41:21
love the color on the boiler Gil.I replaced those brass pieces because they were really tough to bend.The wheelguards will also be good to use your bending pipe on GIl.The ones for the main wheels are tough to bend.It took me ages to get them even vaguely round.
#57 Posted : 13 June 2015 20:28:52
BigGrin Looking good GilCool
kpnuts
#58 Posted : 18 June 2015 09:25:03
Looking awesome.
#59 Posted : 18 June 2015 15:34:20
Great work Gill, its looking awesome Cool
GilShapley
#60 Posted : 19 June 2015 21:46:57
Moved on to the interior of the Cab. Lots of small parts and some delicate painting required.
Parts not glued in place yet as am bending brass rods to make the pipework. Decided not to use the supplied copper wire as it was too much of a faff to try to straighten it out. So this is by way of a dry fit
Also decided to add a wooden top to the seats to match the flooring (Used some planking left over from my Victory Build)
My next job is the funnel covering and the Tender covering. Have delayed this part of the build as it will require me acquiring new skills in so far as the addition of false rivet lines for which I have purchased a ponce wheel. not used one before so this should be interesting/challenging
Current Build:-
6 Pages <12345>»
This page was generated in 0.298 seconds.
