3 Pages <123>
DwCr13 Millennium Falcon Build Diary Options
Impatience
#21 Posted : 28 May 2015 04:04:33
I'm curious why you put primer on the cockpit door that the decal will get attached to? Are you planning to hand paint instead of using decals? I'm very curious what you will be doing with that part and lighting.
The paint booth looks great!! You whipped that up in no time, very impressive!
--Impatience
Current Build: Millennium Falcon
Wish List: Lamborghini Countach LP 500S, Red Bull Racing RB7
galactiboy
#22 Posted : 28 May 2015 16:52:33
Rank: Beginner Level 3
Great work on the spray booth... I need to do something similar as I'm new to having to paint items in this fashion.
I may try to steal everything you did there BigGrin
And congrats on your goal of quitting smoking, I smoked for a number of years and it's very nice not to have to worry or think about them anymore. Not to mention they now cost 4x what the did when I started as a teenager.
DwCr13
#23 Posted : 28 May 2015 16:55:38
--Impatience
Thanks Impatience, I am planing on painting the bulkhead in German grey, I am also thinking about fill in the holes with clear window maker glue once that is done i will flip the bulkhead over and using Tamiya clear blues greens and reds to accent the led lights and decals, seen it done on other models...
Adam
Adam
DwCr13
#24 Posted : 28 May 2015 17:01:16
Thanks, it works for what i am doing and lets me build something out of toothpicks and duck tape!!!
I am slowly getting better about the smoking, cravings are less each day. I just have to give myself time...
Adam
DwCr13
#25 Posted : 28 May 2015 17:18:21
Lighting and paint ideas
DwCr13 attached the following image(s):
Adam
Impatience
#26 Posted : 28 May 2015 20:02:05
--Impatience
Adam
Sounds great! I'm looking forward to seeing how it turns out. I've already applied decals, so I won't be making any modifications to that area, but I'm getting REALLY tempted to start making other modifications. Must...stick...to...OOB...build...UGH!
DwCr13
#27 Posted : 28 May 2015 21:02:50
Impatience wrote:
--Impatience
Adam
lol, i understand, I keep wanting to start "jumping" ahead of myself and do things but i promised myself i would take my time with this project!!!
Stick to your guns and build your Falcon the way you envision it!!!
Adam
DwCr13
#28 Posted : 01 June 2015 19:11:00
well started working on painting and have been working on dry brushing...
Adam
dandare
#29 Posted : 01 June 2015 19:58:18
Sweet Job
keep those updates coming
Dan
RogerThornhill
#30 Posted : 05 June 2015 05:13:57
Very impressive...and yes keep those updates coming I will be following closely.
DwCr13
#31 Posted : 07 June 2015 18:30:58
thanks guys, here are some more pics, been working on the nav seats and bulkhead, also got the shadowing and hull base coats done, the control yokes and paints and love the way they came out, did a base coat of gun metal and then highlighted the hand grips in rubber black and center mounts in silver and black rubber, gave it great contrast and breaks up the form... as for pics sorry if they are fuzzy and if i repeat photos
Adam
Adam
DwCr13
#32 Posted : 10 June 2015 23:38:17
few more days and should be getting shipment number 2!!!!!
Adam
DwCr13
#33 Posted : 19 June 2015 21:57:46
still waiting on the next shipment, moved my workstation to a more permanent and lees dining room table location!!! also got the nozzle ports drilled for the quad cannons pics to follow soon.
Adam
DwCr13
#34 Posted : 25 June 2015 20:18:09
Started working on the main hold and Cockpit side panels, trying a trick from Tony Fairclough, face book friend, play book with adding a silver base then working my way up in layers from there... may this hold NEVER look this new and clean again!!!
Adam
galactiboy
#35 Posted : 25 June 2015 20:32:47
Shiny, be curious how this looks once it's done. I could see the silver being a great base. And if you add any scratches later on it would have a very authentic look.
And I may have missed it, what did you do to get the color variations on the back panel of the cockpit? That looks really good so far.
dwayneg
#36 Posted : 25 June 2015 22:40:00
I'm very curious also. I've not seen this yet either but the Man has a plan.BigGrin What do you know that we don't?BigGrin
Tamiya 1/32 P-51D, Revell 1/32 Bf 109G-6 x2 1/32 P-51B, 1/32 Trumpeter Bf109K-4, 1/32 Hasegawa Bf 109E, Testors 1/32 F-117, RMF 1/35 Tiger 1
DwCr13
#37 Posted : 25 June 2015 22:47:43
That's the plan, For the cockpit Bulkhead I filled in the holes with clear window maker, once that had dried and set I painted the spaces with Tamiya clear blue and red paints... that pic was taken with a led flash light in a coffee cup to simulate the passage way that comes with the kit, once i get the model led and battery pack going i will re-eval the colors and add more if need be... thanks for the response!!!
Adam
DwCr13
#38 Posted : 25 June 2015 22:56:15
One of the guys I am following on facebook and Youtube is building the Bandia sets and when he did the R2D2 he used a silver base and then fine misted the blues for the dome and body. it gives this great effect of metal flake,
even though its nots a Falcon build its a great watch for weathering, I watch both Him and Foxx Wolf at model Making Guru
https://www.youtube.com/watch?v=TNlm4xvwuao
Adam
dwayneg
#39 Posted : 26 June 2015 01:56:56
DwCr13 wrote:
[quote=dwayneg]I'm very curious also. I've not seen this yet either but the Man has a plan.BigGrin What do you know that we don't?BigGrin
https://www.youtube.com/watch?v=TNlm4xvwuao[/quote]
I used clear Tamiya colors also on the back side for the cabin Bulkhead sticker. I like the way it turned out. Its not as bright when I put a light behind it.
I watched the link he has very good ideas and he's funny. Thank you for that. I have following Foxx on his builds.
DwCr13
#40 Posted : 26 June 2015 07:10:57
They are both great guys, I don't know if Foxx is on this forum or the UK, but the both are on the Facebook forum and always willing to answer question or give advice, just be willing to hear every other word being Starship Filth lmao!!!
Adam
3 Pages <123>
This page was generated in 0.221 seconds.
