32 Pages «<1718192021>»
tf64 Spitfire Build Options
#361 Posted : 26 May 2015 22:14:50
Andy,
Hi well the hole build is beginning to take shape now, even more so if I had put the wings together as one piece but I am trying to put it off as long as I can not only due to the size but also the wait, and I have not panelled the under side yet, but a great model to build.
Trev.
#362 Posted : 26 May 2015 23:36:15
Lovely work Trev, looking the biz....Cool Cool
#363 Posted : 30 May 2015 09:50:39
Alan,
Hi just read your post and thank you for your time, these reinforcements parts sometimes you think not more !! but after you have fitted a few metal plates your very glad that you have, and I must say that I have fitted more myself in the wing section all good fun.
Trev.
#364 Posted : 13 June 2015 19:25:41
UPDATE:SPITFIRE.
PACK 22.
130615.
Received today Pack 22 looks like lots to do there's wing plates, upper and lower, Fuselage plate, Engine plate, Engine support frets, upper wing fairings, Dashboard.
1 Upper wing fairing 4
2 Upper wing fairing 5
Stage 84.
Lower wing plate 17 18 19 23.
Upper wing plate 10
Template.
Looks to me as we have a plate missing (bottom )and the one at the top looks to big.
Stage 86.
Fuselage plate 1. 2. 4.
Engine plate 1.7.
Template.
Stage 87.
Engine support fret.
Upper wing fairings 1.2.
Paper Dashboard.
UPDATE: AMENDMENT TO ISSUE 85.
The wing plates that appear to be missing or the wrong shape will be supplied in future issues.
Apologies.
Trev.
#365 Posted : 14 June 2015 11:15:25
Hi Trev, once again I will look forward to seeing your progress when fitting the latest parts... good luck with it... Cool Cool
#366 Posted : 14 June 2015 11:43:04
Hello Alan,
Still working on Stage 21 but looking forward to stage 22.
Trev.
#367 Posted : 14 June 2015 11:48:27
Regarding Stage 85, see the info in the official build for Stage 85 which notes as follows:
"Note that the missing arrowed plate from the template (lower wing plate 20), is provided in Stage 101 and is fitted in Stage 102. (This also applies to the template/content of Stage 91)."
The plate shape for the smallest plate is correct (lower wing plate 23) and the template has no bearing on this. But you appear to be missing the small squarish plate (top left) in your parts image photo (lower wing plate 18).
#368 Posted : 27 June 2015 08:35:02
UPDATE:SPITFIRE.
270615.
AILERONS.
First was to retrieve and identify ailerons left and right and the template to mark the aileron.
Using the template to transfer the lines onto the aileron plate with a scriber and ruler.
With the lines now transferred to the plate the next job was to glue to the fret, best to check that sides are aligned before gluing, you may find that you will have to sand to shape.
Test fit to the wing and adjust if necessary,should not be a tight fit.
More soon
Trev.
dandare
#369 Posted : 27 June 2015 08:54:57
Sweet Job as always Trev
really coming along nicely
Dan
#370 Posted : 27 June 2015 09:02:07
BigGrin Starting to shine now Trev and nicely doneCool
#371 Posted : 27 June 2015 09:12:03
Dan thanks for looking, the wings are starting to shape up now but as you know it all takes time as with your Zero build.
Thanks Dan.
Trev.
#372 Posted : 27 June 2015 09:12:32
Awesoke job Trev, its looking great Cool
#373 Posted : 27 June 2015 09:15:33
Thanks for your comments and for looking in,that shine has caused problems with the pictures.
Trev.
#374 Posted : 27 June 2015 09:19:40
Hi Davetwin,
Good to hear from you and thanks for your comments, more to follow.
Trev.
#375 Posted : 27 June 2015 09:44:18
UPDATE:SPITFIRE.
270615.
ENGINE SUPPORT.
Engine support has three sides to glue together, after removing fret and sanding down then dry fitting, making sure that when positioned in the fuselage it fits correctly (note Mr T Build) you will see that the sides will splay out, this is how I have fitted my engine support to my Spitfire as you can see from my pictures, not much more to say on this bit other than thanks for looking.
Trev.
#376 Posted : 27 June 2015 11:12:50
Beautiful work Trev, the iconic shape of the wing is really there to see now...Cool Cool . Loving the build...
#377 Posted : 28 June 2015 08:04:02
Alan,
Thanks for looking in, the next part will be airbrushing the wheel arches and fitting the undercarriage.
Trev.
#378 Posted : 03 July 2015 21:52:13
UPDATE:SPITFIRE.
030715.
SPRAYING UNDERSIDE OF WING.
This involves masking of the area where the undercarriage will be fitted, first to primer then final coat using XF76.
Mask of area.
Then I sprayed with Tam Grey Primer.
My final coat Tam XF76.
Next I will show you how I fitted the undercarriage.
Kind Regards,
Trev.
#379 Posted : 03 July 2015 22:05:14
#380 Posted : 03 July 2015 22:32:40
Nice one Trev, I am really enjoying your build Cool
This page was generated in 0.361 seconds.
