De-greasing plastic. Options
#1 Posted : 24 May 2015 17:07:36
I am sure many of you are aware of this product and some of you aware of its application in the model building world but for those of you who don't...
Decorators Sugar Soap is an excellent degreasing product for plastic. I purchase it in the spray bottle seen here which is particularly handy if you want to de-grease a large plastic ships hull for example. simply spray on and wipe down.
For small parts on sprue decant some into warm water and soak the parts, unlike washing up liquid this will not leave residue behind.
https://www.toolstation....azLBRDxrdGMx-Km4oQBEiQA
WildRover
#2 Posted : 24 May 2015 17:35:57
i use white vinegar, but same process...
Completed: Earth, Moon, Sun Orbiter
Build a Model Solar System
Under Constuction: HMB Endeavour
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#3 Posted : 04 June 2015 20:35:21
This is definately a new one to me, thanks for the tip Cool
meffman
#4 Posted : 22 September 2015 14:39:38
I started building models nearly 30 years ago and have always washed the parts leave them on the sprue's get a bowl and some warm water + a small amount of washing up liquid dunk the sprue's in leave a few minutes rinse and leave to air dry....what this washing process does is it takes away the mould releasing agents that the makers use by doing this you have an excellent grease free surface which in turn will paint adhere better
MeffMan :)
greyhawk
#5 Posted : 22 September 2015 15:24:28
MeffMan :)
Same. I actually use my normal daily dish water. Dump the plastic parts in, wait a little, retrieve the parts, do the actual dishes.
This page was generated in 0.126 seconds.
