Peter G Options
Peter G
#1 Posted : 20 May 2015 03:00:48
Quarterdeck, Vol 44 - the support lugs on ribs 21/22/26 are not aligned, the ones on rib 22 being higher with the result the bottom edge of the decking 86a/b is 3mm above the cross beam at rib 21 when the deck's stern edge is properly located. Any problems caused down the track if I bend down the front edge so the deck surface has a curve in it? Regards, Peter G
#2 Posted : 21 May 2015 00:31:11
Hi Peter, this one took me a little while to work out but before I get to the answer can I ask you to ensure you give a title to your posts relevant to the discussion topic rather than just entitling them with you name, I almost missed your post completely..... A pic of your problem here would have also saved me some time....
Without the aid of some pics and if I am following you correctly there is a slight slope to the decking, higher at the stern curving towards the centre. I would be looking to remove a little off the ears of rib 22, no more than 1mm to help you achieve a flowing curve to the decking, I would also be using the line of the gun ports as a guide, if you notice the gun ports should also have a nice flowing line rising slowly from the centre towards the stern and the bow.... The line of the gun ports gives you a good clue as to how the decking line should be..... Hope this helps but if you have any further queries then let me know..
This page was generated in 0.082 seconds.
