18 Pages «<34567>»
Caldercraft H.M.S Agamemnon Options
#81 Posted : 17 May 2015 22:05:55
BigGrin Hi All
No Gun ports cut today as I have been busy spraying up the last D51 parts so in between spraying and drying I added the stern counter and stern gallery's using the pre -cut parts, note the stern gallery is only pinned on at the moment as there are still parts to add here. Made a hash of the upper stern counter and cut them short, it was my own fault for misreading the instructions but managed to repair the damage in the end. A fair bit of fetling was involved with the shaping of the formers and upper and lower capping pieces. Still looks a little bare here but there is still loads of etch, shaped brass strip and castings to go on yet. Now I must do the Gun ports so I can start the second planking. More soon.
der Gohfelder
#82 Posted : 17 May 2015 22:29:55
Hi Andy!
A nice work you made, I really like it! Have fun with the gun ports BigGrin
Regards, Bernd
#83 Posted : 18 May 2015 14:51:10
Hi Andy.
Very nice progress. Interrsting way of doing the round houses off the model.Love the stern gallerrys.
Look forward to seeing the next instalment Ian Cool Cool BigGrin
#84 Posted : 18 May 2015 23:09:44
BigGrin Hi Bernd and Ian
Thanks for looking in and your comments. The construction of the round houses is quite simple really and the whole bulkhead fitted onto the hull without any adjustment. I have always known the round houses are the ships toilets but had wondered in the past how they worked so to speak, but the inclusion of holes in the lower most former made things perfectly clear as these poop chutes are over the edge of the deck. Blink Laugh LOL .
#85 Posted : 18 May 2015 23:19:49
Coming on nicely Andy. Love it mate.
Chris BigGrin
#86 Posted : 18 May 2015 23:50:45
Looks fab Andy, enjoy your time with the gun ports.....BigGrin BigGrin ... A task some enjoy and others don't, me I on the quite enjoy side.....BigGrin BigGrin ..
#87 Posted : 19 May 2015 17:41:52
BigGrin Hi Cris and Alan , Thanks for looking in and your commentsCool Cool
#88 Posted : 19 May 2015 18:00:28
#89 Posted : 19 May 2015 23:29:53
BigGrin Thanks for looking in Steve, things will slow down a bit now but I have to say this is a great kit to buildCool
#90 Posted : 24 May 2015 22:19:04
BigGrin Hi All
Some more progress, the gun ports are now all cut out and the seven central ports as indicated on the plans lined and painted Ochre Red, these gun ports do not have lids so the second planking fits flush with them. Two wallnut planks 1mm x 5mm have been laid either side of the hull of the secondary planking the first lower plank follows the main wale line I marked on the hull previously and all planks will now follow this master plank.
When I had a bit of time I made up the ships stove, the stove is supplied in several flat cast pieces that fit reletivly well together after some fettling and a small amount of filler. In the picture its been undercoated and the first coat of black paint, I also added a penny to give an idea of size. The rear gallery of the central stern gallery has also had a coat of paint Black and Yellow Ochre this already looks quite eye catching but will look even better when the white window frames are fitted. More soon.
#91 Posted : 25 May 2015 00:19:32
You've made very fast progress there Andy. Looks nice, clean and very smooth. Top job pal
Chris.
#92 Posted : 25 May 2015 09:17:55
BigGrin Hi Cris , Thanks for looking in and your commentsCool
#93 Posted : 25 May 2015 13:59:18
Clean build Andy, looking good.
Trev.
#94 Posted : 25 May 2015 19:40:34
BigGrin Hi Trev
#95 Posted : 25 May 2015 19:51:55
BigGrin Hi All
Planking continues above the Main wale line, one side is now done and all the ports cut out and squared off. The upper most planking is only partially trimmed to shape so as to give support to the upper gunwales when I turn her over the do the lower planking. On the other side I am about a third of the way up, cutting the gun ports out and ensuring there square takes a lot of time but worth it in the end I think. The second planking still needs a good sanding back but she's starting to look the part now with her second skin. more soon.
#96 Posted : 25 May 2015 21:33:46
BigGrin Wow the planking is looking stunning Andy and the gun ports are spot on lovely work
der Gohfelder
#97 Posted : 25 May 2015 21:37:34
Nice to see her growing, a perfect job you made !!
Regards, Bernd
#98 Posted : 25 May 2015 23:04:11
BigGrin Hi Martyn and Bernd
Thanks both of you for your comments and looking in. Loads more to do yet 2k + copper plates yet to be fittedDrool Love Crying Laugh
#99 Posted : 25 May 2015 23:41:10
Simply looking great Andy and some wonderful progress being made... Drool Drool .. Pleasure to follow....
Hans
#100 Posted : 26 May 2015 13:57:46
Good clean build there Andy, will be following with interest.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
18 Pages «<34567>»
