Brass wire Options
macthfac
#1 Posted : 19 May 2015 05:50:07
Rank: Newbie
I have reached Stage 44 of Build the Spitfire. On page 153, brass wire is required for the construction of the cockpit right-hand side but the size of the wire is not identified in Steps 4 to 6.
1.0 mm Brass wire was supplied with Stage 43 and 1.5 mm Brass wire was supplied with Stage 44.
Which Brass wire do I use in Stage 44?
#2 Posted : 19 May 2015 07:11:36
Looking at the official build log I would say you use the wire that came with issue 44 for the cockpit
#3 Posted : 19 May 2015 08:57:56
Correct, the 1mm brass wire from 43 is used in Stage 53
macthfac
#4 Posted : 19 May 2015 09:30:57
Rank: Newbie
Thank you for your assistance and apologies for placing the request in the wrong area. At my age it takes time to adapt to new technology.
This page was generated in 0.130 seconds.
