Wing rib 11 pack 4 Options
ALW
#1 Posted : 16 May 2015 23:20:02
Hello all
I've just completed pack 4 and all is looking good but I'm a little concerned that wing rib 11 is not fitted correctly.
It is fitted at an angle (looking down)as per the instructions but viewing from the front it is not vertical.
Is this the correct orientation?
Thanks
Wing rib 11.jpg (377kb) downloaded 43 time(s).
#2 Posted : 17 May 2015 12:13:23
The slight lean to the left is as it should be., the same rib in the right-hand wing will have a slight lean to the right.
ALW
#3 Posted : 17 May 2015 12:15:53
Thanks Mr T.
That's a relief!
This page was generated in 0.090 seconds.
