Joined: 03/02/2015 Posts: 457 Points: 1,389 Location: Crawley, W.Sx, UK
Hello all I've just completed pack 4 and all is looking good but I'm a little concerned that wing rib 11 is not fitted correctly. It is fitted at an angle (looking down)as per the instructions but viewing from the front it is not vertical. Is this the correct orientation? Thanks Alan
The slight lean to the left is as it should be., the same rib in the right-hand wing will have a slight lean to the right.
Thanks Mr T.
That's a relief!
