Looking good Mike  The sanding does take a bit of work and with 2mm thick planks you can take a fair bit off - just be careful on the curves as it's easy to get carried away and wear them a bit thin. Steve
Fabulous job Mike and now it's decision time.
 Rank: Pro  Groups: Registered
Joined: 17/02/2014 Posts: 124 Points: 376 Location: Wales, UK
z8000783 wrote:Fabulous job Mike and now it's decision time. Thank you, the decision will wholely depend on what the wood work looks like once the sanding is finished!!
It will look great judging by the planking.
Hi Mike. Superp job on your hull. Look fowrad to seeing your progress Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Mike, That hull looks spot on, You`ve made a very good start, keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Mike, Well done, your hull looks great. From what I've seen you will be able to go either the painting or staining route. The hard work has been done, and done well I bought a small "Mouse sander" this has really saved time (& energy). Just take it slow. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
Garth wrote:Hi Mike, Well done, your hull looks great. From what I've seen you will be able to go either the painting or staining route. The hard work has been done, and done well I bought a small "Mouse sander" this has really saved time (& energy). Just take it slow. Kind regards, Garth Thanks for looking in. I have a mouse sander and was wondering about using it on the hull. How was your experience of using it?
Hi Mike I used the mouse on the Victory hull, works well, but as Garth said very slowly and carefully. It does the job well and does not use much muscle power, rather a little brain power and patience. Enjoy. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Mike A lot of hard work put in here I can see and my word it looks great. Happy Modelling
Hi Mike, I originally bought the sander for my Bismarck’s hull. I must have given it about 20 coats of primer, sanding between each coat. On my Victory, I used it with course sandpaper to shape the ribs and then with progressively finer paper to sand the planking. Just as we all say – take it slowly. If you are unsure about a specific area – sand that piece by hand. I found the pre-cut sand paper quite pricy. As I decided to leave my pins in my Victory’s hull, the sandpaper did not last very long. I then bought sheets of sand paper and double sided taped them to a worn piece that has the valcro on and then cut the triangular shape out using a craft knife. I used tape designed for carpets – it sticks really well. Hope this helps. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 30/04/2015 Posts: 75 Points: 234 Location: St. Louis USA
 Mike I applaud you and your efforts on the HMS Victory (this being your first wooden ship model)!! I just started following your build diary, but I have been subscribe to your build on youtube for a while now. I would like to work on the Victory in the future when I have more confident with modeling over all. I just started modeling this year, with a focus on wooden boats and ships. I am on my 3rd right now. Any advice to give to this beginner. PS I am an artist by trade. I have a great eye and know what it take to make something special. Anyhow keep up the great posts and work!! Regards. -Jordan In the workshop: HMS VictoryFinished builds: Providence Whaleboat
Joined: 25/04/2015 Posts: 154 Points: 462 Location: Northern California, USA
Mike, Looking good. I have been following you on YouTube. I hope my planking turns out half as good as yours. Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon Up Next: We'll See
 Looking great Mike thats a hurdle jumped and now onwards to better things Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks for all the kind words and support, it really is a great build and now the planking is done, it's nice to do something different. All done now up to issue 41. The keel is completely installed now and the initial parts of the gallery are in, the bow deck is on and I've given the whole thing a coat of varnish ready for a bit more sanding. cruorangelussilicis attached the following image(s):
Hi Mike. Progressing Nicely. Look forward to seeing more of your build. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
She's looking good Mike, coming along very nicely. Planking for me is a task I really enjoy but am always pleased to see the end of it and move onto something else....  .. Look forward to your next update.. Regards Alan
Looking good Mick, keep the updates coming
Lower gun deck has been installed as have the gratings. I have decided to paint her and have started with the inner bulwarks in the yellow. On to building ten 12 pounders now! cruorangelussilicis attached the following image(s):
 Very nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
