6 Pages <1234>»
My Jupiter Build Options
dandare
#21 Posted : 14 May 2015 12:58:00
Cracking job Gil
watching this one with great intrest
Dan
GilShapley
#22 Posted : 14 May 2015 14:10:03
Whilst waiting for glue to dry I have sprayed the chassis of the engine
Decided on a Black Satin finish as I think this will look better with the other colours rather than a flat black
Cool Cool Cool Cool Cool
Current Build:-
#23 Posted : 14 May 2015 16:27:06
Looks very nice, and agree it will go with the other colours better than flat black Cool
GilShapley
#24 Posted : 25 May 2015 09:47:00
Found this on utube whilst looking for ideas on how the inside of the cab was painted
https://www.youtube.com/watch?v=oM2A2NEaRqg
Just a bit larger than the model
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
#25 Posted : 25 May 2015 18:10:03
I have been using that video too Gil for reference.I am almost ready to start painting the cab.I think I will use my games workshop paints so I can brush paint the interior.The paint reference calls for a light green. I am going to try to match that.
GilShapley
#26 Posted : 25 May 2015 18:56:42
Been a bit sidetracked on this build.
I liked (so have "borrowed") your idea of a trestle to act as a display stand for this Engine.
Found a reference to a "Typical Rio Grande Southern Trestle" and have used that for a template.
Had some bits of wood laying around in the garage so have constructed my trestle.
Will post a picture shortly.
Not to sure on the suggested green for the Cab so may go a bit darker and I will also brush paint this.
Current Build:-
#27 Posted : 25 May 2015 19:37:29
BigGrin Looking great Gil and putting it on the trestle should set her off nicelyCool
#28 Posted : 25 May 2015 23:11:41
Hi Gil, think the trestle idea is a great one, would end up being a beautiful display... look forward to seeing it....Cool Cool
#29 Posted : 26 May 2015 00:50:01
Gil,
this website has everything you need on building a trestle bridges including supplies
www.blackbearcc.com
The building jigs are very expensive.I am going to build one bent and then make a mold and cast in resin to make my own jig.Way cheaper.
GilShapley
#30 Posted : 26 May 2015 21:40:33
The Trestle is just about complete only now need to decide on the colour. What is the best way to "age" the wood ?
Its size is governed by the size of the model and the space I am going to display it.
The bridge is 36" long and 7" to the top of the rails. I used the plans I posted earlier as a guide plus looking on the web and the various pictures of trestle bridges. Rather than buy a kit this build is made from wood I had in my garage. The only thing I had to buy was the track. I assumed this would be 00 gauge but no, it is G gauge
Now I can get on with the actual model
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
#31 Posted : 26 May 2015 21:56:02
Hi coming on really well.do like this one very much. The tressle looks stunning and will set her off very nicely. Look forward to more of the build.cheers mick. BigGrin BigGrin
#32 Posted : 26 May 2015 22:42:57
BigGrin Hi Gil
Looks great and will set the Jupiter off a treat.
Life colour do a weathered wood set, Links below to paint set and a vid
http://www.graphicair.co...Set-%2822ml-x-6%29.html
https://www.youtube.com/watch?v=ltkRSkYhq1I
#33 Posted : 26 May 2015 22:49:48
That trestle looks brilliant Gil.great job.I think you will have your train finished way before I do.
#34 Posted : 26 May 2015 23:27:47
Hans
#35 Posted : 27 May 2015 09:38:47
Wow, brilliant job on the trestle. What a wonderful way of showing off the model. Great stuff. If the trestle looks this good the Jupiter will look even better.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
GilShapley
#36 Posted : 31 May 2015 18:56:46
Having completed the Trestle Bridge I have now returned to the actual Jupiter Build
Attached is the chassis so far. Fitting the wheels to the axles was "fun" . The suggested method of a small hammer did not work for me and I will have some repair work to do to the paint. In the end I used one of the many clamps I have accumulated. The one I chose has plastic jaws which are quite large and I was therefore able to apply a steady pressure and ease the wheels on gradually. The clamp also has a racket which would normally allow the clamp to hold two items together without slipping. I was able to use this to gradually reduce the distance between the wheels until required size was reached.
1st of no doubt several cock-ups. There are two types of drive wheels. the front drive wheels have a counter weight the rear do not and yes you guessed it, I mixed them up. In order to remove the wheels I had to construct a mini puller so that I could remove the wheels without breaking them (They are a tight fit)
One of the advantages of being a senior citizen and keen D.I.Yer/Modeller is that you accumulate a lot of "bits and pieces" that you store because "they might be useful later" so I was able to cobble together a Heath Robinson device
The Boiler is next. Have already constructed the wooden parts and am now moving on to the metal covers
More later as the build proceeds
Current Build:-
#37 Posted : 31 May 2015 20:48:37
BigGrin Still looks the bizz even with your misshaps, keep the pics commingCool
#38 Posted : 01 June 2015 02:06:18
Wow you are really steaming ahead Gil!! Those wheels are fun aren't they.
I am just starting polishing the wheels.I was waiting on my piece of g scale track to arrive so I could get the wheel spacing right.
#39 Posted : 01 June 2015 07:28:37
Love the bridge mate,Drool it will make an excellent pedestal for your model to sit on. Look forward to the rest of the build .
kpnuts
#40 Posted : 01 June 2015 07:31:30
Looking very impressive, love it.
6 Pages <1234>»
This page was generated in 0.405 seconds.
