5 Pages 123>»
Malc's M23 - James Hunt Options
#1 Posted : 12 April 2015 13:39:44
Well it had to be another Mclaren didn't it?
Not a magnificent 1/8 ( unfortunately ) but a 1/20 Tamiya kit.BigGrin
I've got the sponser decals and a Tamiya upgrade P/E set.
It will give me something to do while awaiting the delivery of the Senna 4/4.
Three months and still not got the first pack yet.
Never mind.. this will keep me busy.BigGrin
mark8454
#2 Posted : 12 April 2015 14:33:01
I will be watching with keen interest and will look for inspiration! :)
#3 Posted : 12 April 2015 17:12:53
Nice kit Malc, I have exactly the same one with the same extras and which I did start building on here previously when I was 'SennaMentalMe'? I was only thinking quite recently that I should perhaps reinstate the M23 diary and carry on from where I left off, but I think that I really ought to concentrate on my 1:32 Spitfire Mk.IX build and three others that I already have on here first?! Blink Sad
Kev BigGrin
#4 Posted : 12 April 2015 17:48:28
Nice looking kit and although it isnt a 1/8 I'm sure you will do it justice Cool
#5 Posted : 12 April 2015 20:17:13
BigGrin Nice kit, will look forward to your buildCool Cool
#6 Posted : 18 April 2015 16:55:32
Here we go. First off the DFV.
I'm going to use Alclad 2 a little more on this build ( I need to practice Airbrush cleaning !! ) so I've used Tamiya grey surface primer then Alclad black and finished with Alclad Aluminium. The covers are in Tamiya Matt black.
#7 Posted : 18 April 2015 16:58:31
A little bit of detailing to finish.BigGrin
#8 Posted : 18 April 2015 21:47:38
BigGrin Nice start and nicely done MalcCool
#9 Posted : 21 April 2015 18:36:35
Nice start to the build Malc and that Cosworth DFV looks pretty realistic already - well done!! Cool ThumpUp
Looking forward to seeing this build develop further and who knows, it might even inspire me to carry on with mine sooner rather than later?
Kev BigGrin
#10 Posted : 26 April 2015 11:14:11
I decided to use a slightly thinner wire for the plug leads and added a red sleeve to each at the distributor made from thin electrical cable with the wire striped out.
#11 Posted : 26 April 2015 11:17:22
Not happy with the venturis that came with the kit. The plate that joins them and the chrome finish are not to my liking.
So I nibbled the plate away with a side cutter and smoothed the edges out. Finished with a light spray of Tamiya chrome silver. Plus a small dab of flat black in the holes.
#12 Posted : 26 April 2015 11:21:52
Early stages with gearbox assembly.
#13 Posted : 26 April 2015 15:44:15
Nice work Malc and making good progress with the engine/gearbox assembly. I did exactly the same as you with the induction trumpets on my kit and they certainly look much better and more to the point, accurate with those plates removed - well done. Cool ThumpUp
Kev BigGrin
#14 Posted : 01 May 2015 16:30:37
The rear discs and brake ducts are quite straight forward. There's a couple of PE parts to add to the sidesBigGrin and I've added some ventilation with a small brush and much cursing!Laugh .
#15 Posted : 01 May 2015 16:35:18
There is no piping for the fuel lines in this kit so I've added some with thin electronic wire sleeving. Also added a fitting to the Fuel pressure relief valve ( I think that's what it is ).
#16 Posted : 01 May 2015 16:36:30
The parts so far.BigGrin
#17 Posted : 01 May 2015 16:41:41
The rear spring units are one piece mouldings so I sprayed them gloss balck then masked off the core and sprayed the spring coil tamiya metallic silver.
#18 Posted : 01 May 2015 20:11:34
BigGrin Very nice work MalcCool
#19 Posted : 01 May 2015 22:21:06
Great work, that engine looks awesome, the detail is fantasitc, look forward to more
dandare
#20 Posted : 14 May 2015 13:08:25
i agree
that engine looks fantastic
great job Malc
Dan
5 Pages 123>»
This page was generated in 0.327 seconds.
