13 Pages «<678910>»
HMS Guadeloupe (ex French Le Nisus), Brick de 24" by Jack.Aubrey - Scratch build - 1:48 Scale Options
michu
#141 Posted : 21 April 2015 12:23:06
This is a stunning work Jack, you have some mad skills and a patience of a saint. Every update is a treat - and I love reading your build notes as well. For some reason I read it in my head in a voice-over film noir narration style... It just fits :-) lol
Happy building :-)
#142 Posted : 21 April 2015 17:33:08
Very nice Jack, up to your usual high standard Cool
#143 Posted : 21 April 2015 21:04:52
very very nice finish you are achieving love it
jack.aubrey
#144 Posted : 23 April 2015 12:18:02
First of all I have to thank all of you for your motivating and supporting comments . . Thanks michu, davetwin and jase.
but let's go on with new things . .
Wednesday, April 22, 2015
Both sides of the bulwarks, from the wales up are terminated . .
I was impatient to see the true color of the wood I used for the second planking, so yesterday evening I applied a coat of oil for wood in the newly planked area. Today, the oil has already been absorbed and then the hull was again manageable for other works.
Obviously, at first I resumed the works equipped with a digital camera and I took a lot of photos, also thanks to a proper daylight.
This afternoon I started applying additional strips below the wale, for now only on the right side. . of course, from now the work gets longer.
I have other images to display . . see you tomorrow with a new message. Jack.
Brick%20by%20JackAubrey/P1100257_zps1iffnrlb.jpg
Brick%20by%20JackAubrey/P1100256_zpslrbqwcht.jpg
Brick%20by%20JackAubrey/P1100252_zpsujhfjzeu.jpg
Brick%20by%20JackAubrey/P1100248_zpsxu0fmqn8.jpg
Brick%20by%20JackAubrey/P1100246_zpsvfcr6c1i.jpg
Brick%20by%20JackAubrey/P1100249_zps2ikdgjf7.jpg
#145 Posted : 23 April 2015 23:32:14
Lovely work Jack, she looks fab.... Cool Cool
jack.aubrey
#146 Posted : 24 April 2015 10:15:54
Thanks Alan for your encouragement . . Jack.
Thursday, April 23, 2015
other images dating back to yesterday. . from different viewpoints.
Regards, Jack.
Brick%20by%20JackAubrey/P1100255_zpsv9zo4pmy.jpg
In the next two pictures, due to the rather flattened viewpoint, we can see how the deck planking is anything but perfect. . In fact, the strakes don't have a constant curved shape and tend to straighten amidships. This obviously cannot be noticed if you look at the model from other viewpoints. All this is originated by errors that, if I should repeat the same experience, I will now be able to avoid. Unfortunately this is the price to pay when you have to build an experience never done before.
Of course I'm relatively not worried because with the deck fittings and the ordnance installed the line of each strake will be often interrupted and then you will not notice these imperfections. . which, anyway, remain such.
Brick%20by%20JackAubrey/P1100254_zpspb7hq0xl.jpg
Brick%20by%20JackAubrey/P1100253_zps5xnji8es.jpg
Brick%20by%20JackAubrey/P1100251_zpsylsdp2qt.jpg
Brick%20by%20JackAubrey/P1100250_zpsethkmuev.jpg
Brick%20by%20JackAubrey/P1100247_zpsa90qd3lu.jpg
Gibbo
#147 Posted : 24 April 2015 11:57:02
If you hadn't pointed that out Jack i dont think anybody would have really noticed, beautiful work either way.
Paul
jack.aubrey
#148 Posted : 26 April 2015 16:55:09
Saturday, April 25, 2015
The implementation of the second planking, from the wales downwards, continues. . Till now I'm focused on the right side of the hull only.
The area below the waterline will be covered with copper plates while the area above, I believe from the waterline to the lower wale or perhaps even the wales themselves, should be painted black. So the accuracy in the installation of the second planking may have a relative importance.
But personally I'm trying to do a job as good as possible because I believe that the more you know about this matter the more it is better . . in this case I'm experimenting some techniques new to me that at the moment I feel useful to consolidate my skills for the future.
The particular shape of the bow of this hull not certainly makes things simple, in particular the difficulties are concentrated in five or six strakes positioned below the lower wale. This implies an abundant use of the so-called "drop planks" although from the photos you probably see little.
Cheers, Jack.
01 Brick%20by%20JackAubrey/20150425_183921_zpszmz6tznr.jpg
02 Brick%20by%20JackAubrey/20150425_183751_zpsgow6u73a.jpg
03 Brick%20by%20JackAubrey/20150425_183858_zpshqbkjppk.jpg
04 Brick%20by%20JackAubrey/20150425_183827_zps4w3zk61g.jpg
jack.aubrey
#149 Posted : 26 April 2015 16:58:15
Paul
Hi Paul, I believe it is important to show not only the good things but also the mistakes. It is from our mistakes (and learning from the others experiences, although if mistakes) that we can improve our craftmanship. Don't you think so ?
Regards, Jack.
jack.aubrey
#150 Posted : 30 April 2015 10:22:44
Wednesday, April 29, 2015
Two days ago I completed the planking on the right side of the hull . . then, I had two days with some health problem and did not progress further.
Now it remains to plank the left side, then finish the keel/stern/stem/breakwater. And finally a nice final sanding/smoothing.
In view of my experience with the right side, I estimate in four, perhaps five sessions of three hours my efforts to finish.
I do not think that I will post new messages or images until the end of the left side, except to answer to messages from other users: I would not have anything new to show, only a inverse photocopy of these images.
And then I have another very important commitment: I must setup a plan on how to proceed further with this model, both as a sequence of tasks to be carried out but also as choices of presentation/colour scheme. Everything by studying in depth the ANCRE plans. So far I have proceeded almost with improvisation, now it's time to change the method.
Cheers, Jack Aubrey.
01 Brick%20by%20JackAubrey/20150429_170628_zpscjk4khy4.jpg
02 Brick%20by%20JackAubrey/20150429_170720_zpsno9lcalx.jpg
03 Brick%20by%20JackAubrey/20150429_170733_zpschpr7voc.jpg
Gibbo
#151 Posted : 30 April 2015 14:41:47
Indeed i do Jack, well pointed out.
Paul
jack.aubrey
#152 Posted : 08 May 2015 11:20:27
Thursday, May 7, 2015
Today I have finished the application of the second planking on the remaining side, the left side. As I expected it took the time previously estimated.
For the moment I haven't pictures to show but I'll arrange for asap.
At the end of the day I also started to cover with veneer the keel and I'll continue with the stern and the stem. These will be the upcoming activities that will bring to completion next days.
Sincerely, Jack.
#153 Posted : 08 May 2015 12:14:49
Jack
This is a beautiful looking build, its so neat and clean! I can see a lot of care has gone into this.
I had a read back and you mentioned earlier that the planks on the deck werent quite right, you struggled to get a continuous curve, I must say that I struggled to see that myself. Not sure if its just my lak of experience with plank on frame builds but I really had to look hard to see it, in any case I though it looked amazing! Cool
jack.aubrey
#154 Posted : 10 May 2015 14:34:42
Sunday, May 10, 2015
As promised Thursday, I took some photographs of the brick with the second planking completed. Also part of the keel, the stern post and the stem are in an advanced stage of completion. Although it may seem unnecessary when you consider that the underwater hull part will be covered with copper plates, I differentiated the wood that finishes the keel using mahogany instead of Tanganyika.
Images are set in a rural agri-ecological or eco-agriculture environment, where you can even see wild strawberries . . . Power of biodiversity (but anyway it's now time to mow).
Other images from different viewpoints will follow soon.
Regards, Jack.
01 Brick%20by%20JackAubrey/P1100258_zpsguldtbcj.jpg
02 Brick%20by%20JackAubrey/P1100259_zpsj6uc8wuq.jpg
03 Brick%20by%20JackAubrey/P1100260_zpsgir9td03.jpg
04 Brick%20by%20JackAubrey/P1100261_zpsktj8tdkv.jpg
#155 Posted : 10 May 2015 21:29:38
Jack
Been a while since i last looked in on this one and wow its coming along wonderfully.
So neat and exact the planking it looks stunning.
Gibbo
#156 Posted : 10 May 2015 23:09:25
Beautiful work Jack, really enjoying it thank you.
Paul
jack.aubrey
#157 Posted : 11 May 2015 13:21:26
Strawberry fields forever . . . . (in memory of the fab four John, Paul, George e Ringo !!)
Other images belonging to the same day of the yesterday's message.
To close, thanks to Paul, Tony and davetwin for the positive comments about my work. Thanks again . . Jack.
01 Brick%20by%20JackAubrey/P1100262_zpsmg1wvc81.jpg
02 Brick%20by%20JackAubrey/P1100263_zpsqcczweff.jpg
03 Brick%20by%20JackAubrey/P1100264_zpsmuswonpa.jpg
04 Brick%20by%20JackAubrey/P1100265_zpstcqclo9v.jpg
jack.aubrey
#158 Posted : 15 May 2015 09:01:58
Thursday, May 14, 2015
Yesterday and today I worked on planning and building of the gunwale.
I discarded the idea of ​​using a wooden strip to be bent, which is rather difficult in my case, so I opted to crop the various segments that make up this element using a birch plywood, 2mm thick. The piece will be painted black, then this plywood, of very good quality, is probably the best solution for my task.
Using cardboards properly prepared I took over the external shape of the gunwale tracing with a pencil the outline of the hull.
Then I scanned the cardboards on the computer and I used the images as background for Autocad. I traced over the outside shape of the gunwale, I refined the curved line in some areas, although for only a few tenths, and then I got the internal gunwale shape, 9 mm internally of the external line.
Finally with the Autocad "mirror" function I reversed the pictures and I printed them.
At this point, it was enough to crop the parts to be glued onto the plywood and start cutting. Operation currently ongoing. The process seems in practice, so far, very good. . we'll see if this is true also for the remaining pieces to be cut . .
Meanwhile I submit you four other images, greetings, Jack.
01 Brick%20by%20JackAubrey/P1100266_zpshdxsnvni.jpg
02 Brick%20by%20JackAubrey/P1100267_zpshhqce4my.jpg
03 Brick%20by%20JackAubrey/P1100268_zpshklm9py9.jpg
04 Brick%20by%20JackAubrey/P1100269_zpsie5j4755.jpg
Gibbo
#159 Posted : 15 May 2015 13:38:01
Hi Jack
I know it's going to look good either way but just seems a shame you're going to copper over such superb woodwork.
Paul
#160 Posted : 15 May 2015 16:45:24
Beautiful looking model so far Jack ThumpUp
13 Pages «<678910>»
This page was generated in 0.710 seconds.
