Ground Clearance Options
Carl71
#1 Posted : 19 April 2015 14:28:17
Hi all, I have been driving my RB7 for a while now.. Great fun can not wait for the two speed gearbox!! I have noticed ground clearance at the back is an issue with a large amount of wear on the rear diffuser. Is it possible to use the same suspension extenders we used on the front, on the back to bring it up a little also?
Thanks
#2 Posted : 19 April 2015 15:40:38
You could always try it
Carl71
#3 Posted : 14 May 2015 08:58:51
Well I just received my reorder of the issue which had the ride height front suspension extenders. I fitted them to the back end which sent up the ride height heaps. They will need to be cut down a little but if you are concerned about tearing the bottom out of your car then this is money well spent.
CarlBigGrin
Nightrider
#4 Posted : 20 July 2015 06:20:23
Hi Carl. What issue # is the replacement shock extender part for the front?
As I want to replace the ones on the back to increase the height ?
Thanks in advance
Nightrider
This page was generated in 0.172 seconds.
