 Rank: Beginner Level 1 Groups: Registered
Joined: 03/11/2014 Posts: 9 Points: 27 Location: Brisbane
Hi all, I have been driving my RB7 for a while now.. Great fun can not wait for the two speed gearbox!! I have noticed ground clearance at the back is an issue with a large amount of wear on the rear diffuser. Is it possible to use the same suspension extenders we used on the front, on the back to bring it up a little also?
Thanks Carl
Well I just received my reorder of the issue which had the ride height front suspension extenders. I fitted them to the back end which sent up the ride height heaps. They will need to be cut down a little but if you are concerned about tearing the bottom out of your car then this is money well spent. Carl
 Rank: Pro  Groups: Registered
Joined: 30/04/2013 Posts: 105 Points: 301 Location: Perth
Hi Carl. What issue # is the replacement shock extender part for the front? As I want to replace the ones on the back to increase the height ? Thanks in advance
Nightrider
