4 Pages <1234>
Andy's Senna MP4/4 Build Options
#21 Posted : 05 April 2015 17:35:23
BigGrin Hi All
Packs 10-11.
Made up the left rear brake parts then added the four hoses to the right radiator housing, I have included a picture of how Im stretching the hoses with a pair of metal tweezers. Next the left rear upright was assembled, the hub was also drilled out like the brake discs then the brake parts added to make a complete hub. Assembled the rear shocks and put the hoses on the T-piece then everything was inked as instructed. Started to construct the inner and outer gearbox parts adding the components as instructed, the two brake reservoirs were then made up. Assembled the right rear upright and finally added the brackets to the lower wishbone and gearbox.More soon.
Ringo
#22 Posted : 07 April 2015 13:50:25
Hi Andy BigGrin
Looking really good, a really clean build with nice little details.
I'm so looking forward to getting these packs.
Good tip with the hose stretching. Can I ask if you needed to soften in warm water or something first?
Cheers,
Si
Senna fan since I was tiny. F1 geek. Modelling noob... 😊
Currently attempting:
McLaren MP4/4
Bentley 4.5 litre
#23 Posted : 07 April 2015 21:05:20
BigGrin Hi Si
Thanks for looking in and your comments. You will soon be drooling over your own packs as the detail just gets better and better. I dint pre-heat or anything with the tubes I just inserted the Tweazer point and left it for a minute or two the stretch then inserted it onto the stud, some took a couple of try,s as you need to be quick but they all went on ok.
dandare
#24 Posted : 11 April 2015 09:47:23
Nice start Andy, shot through those saved up packs & she's looking great
Dan
#25 Posted : 11 April 2015 09:58:36
BigGrin Hi Dan thanks for looking in and your commentsCool
Ringo
#26 Posted : 12 April 2015 10:09:58
arpurchase wrote:
BigGrin Hi Si
Hi Andy,
Nice one, cheers for the tips
Si
McLaren MP4/4
Bentley 4.5 litre
#27 Posted : 16 April 2015 23:36:18
BigGrin Hi All
Pack 12. Assembled the upper gear box and added the nuts the only thing I did different here was to add the glue to the bolt holes as instructed but then I pulled them out about half way to draw the glue down then pushed the bolts home. Made up the rear shocks as instructed, added the various hoses and anti roll bar. Then added the rear left suspension arms, quarter panel and hub. More soon.
#28 Posted : 17 April 2015 10:24:56
Very nice!
#29 Posted : 17 April 2015 10:44:29
Beautifully built Andy, you are doing this model great justice, looking forward to seeing more - well done. Drool Cool ThumpUp
Kev BigGrin
#30 Posted : 17 April 2015 20:55:47
BigGrin Thanks both of you for looking in and your commentsCool
#31 Posted : 18 April 2015 10:26:44
Nicely done Andy, another great update....Cool Cool
#32 Posted : 18 April 2015 16:40:01
Very nice . BigGrin I'm looking forward to get going on mine.
#33 Posted : 18 April 2015 21:45:57
BigGrin Thank you everyone for looking in and your commentsCool
#34 Posted : 20 May 2015 16:05:44
BigGrin Hi All
Pack 13 finished off and pack 14 done. Added more gearbox outer parts along with the oil cooler and rear jacking point, more tubes added and then made up the last rear wheel hub and rear tyre and added the hub and suspension parts to the right hand side.
Added the oil tank then made up the under body middle and rear adding the parts and heat shield material and mounting brakets then finally the heat exchanger and the two tailpipe end plates. More soon.
Steve279021
#35 Posted : 30 May 2015 08:43:31
Andy, I noticed as I have just done this bit. The hose which goes from the rear of the box, then under the oil cooler and then up to a union in the top of the box. I noticed that you didn't pass the hose through the rear suspension mount plate and you took it over it instead. I doubt it will make any difference. Just an observation.
Dodge charger build complete
#36 Posted : 30 May 2015 09:20:48
BigGrin Oooooooooops missed that and will rectify it, thanks for the heads upCool
#37 Posted : 17 June 2015 08:44:32
BigGrin Hi All
Pack 15 arrived so on we go. Added the inner manifolds and cam covers then the outer side pieces then the plug caps and covers. The manifold intakes were next and the uppers added to the plenum chamber. A small conectot was added to a pipe on the radiator housing and two oil pipes attached to the gearbox assembly.Next the oil and water pumps were added along with the engine lower cover To finish this part of the engine build the alternator and belt were attached. Last of all this month the header tank assembly was made up ready for fitting and the brake lines were added to all four brake calipers. More soon
dandare
#38 Posted : 24 June 2015 08:59:44
Great Stuff Andy
the Engine block is a piece of art, dont you think? and its not fully assembled yet.
Dan
#39 Posted : 24 June 2015 10:17:34
Great build!
#40 Posted : 24 June 2015 17:40:46
BigGrin Thanks everyone for looking in and your commentsCool
4 Pages <1234>
