32 Pages «<1516171819>»
tf64 Spitfire Build Options
#321 Posted : 30 March 2015 22:36:46
Jase,
Thank you for looking with the metal skin now in place I can feel the weight becoming more and more now a very solid plane.
Trev
#322 Posted : 30 March 2015 23:28:57
More great work Trev, keep em coming.... Cool Cool
#323 Posted : 31 March 2015 08:45:11
I love your build, Trev!
dandare
#324 Posted : 13 April 2015 18:49:37
Hi Trev
its been a while since i checked out your build, its been great catching up! your work is truly fantastic
Dan
#325 Posted : 13 April 2015 21:28:34
Hi Walter,
Sorry I missed your last post thank you for your comments , your build is looking great looking forward to your next update
Trev.
#326 Posted : 13 April 2015 21:35:44
Hi Dan
Good to see your post to me and thank you for your comments, and for looking in, there will be a Spitfire update soon.
Trev.
#327 Posted : 14 April 2015 21:58:04
UPDATE: SPITFIRE.
140415.
PACK 20.
Pack 20 looks interesting we have the Propeller shaft, motor retainer, Allen screws, also upper wing plates 8/9/19 more nuts, screws, and washers.
It looks to me like a lot of work on the metal skinning which I am feeling more confident about.
Propeller Shaft.
Motor Retainer.
Allen Screws.
5mm Nut.
Upper Wing Plate 4.
Nails.
Template.
Upper Wing Plate 8/10/13
Template.
5mm Screws/Nuts.
M4 Washers.
2 Metal Plates.
More Soon,
Trev.
#328 Posted : 15 April 2015 21:57:13
UPDATE: SPITFIRE BUILD.
150415.
Wing Plates.
Just a small update on the work so far with the wing plates I have managed to secure upper wing plates without problems although I did start to run out of alignment towards the end of the wing, this I corrected by hand cutting a new plate and fitting in place. I still feel that I am learning on this build with the skinning and there's a lot more to do yet.
This picture shows the a cardboard template cut to size and ready to draw down onto the metal plate.
This picture shows sample shape ready to cut out.
This shows shape ready to cut out.
This shows shape ready to fit.
This shows plate fitted to wing ( the wing looks out of shape just the angle)
This shows the wings to date.
Trev.
#329 Posted : 15 April 2015 22:47:16
Very nice Trev, your panelling lookgs great ThumpUp
#330 Posted : 15 April 2015 23:16:21
Hi Trev, BigGrin
Panels look spot on, very neat.Cool
Derek
#331 Posted : 16 April 2015 00:15:00
She really is coming along now Trev, great work once again....Cool Cool
#332 Posted : 16 April 2015 12:12:12
#333 Posted : 16 April 2015 12:35:27
This looks very nice Trev, love the paneling. Do you have any way of letting me know the thickness of the plating? I have a little aircraft project lined up and Id like to get some of around that thickness.
#334 Posted : 16 April 2015 21:18:21
Hi Davetwin,
Thank you for your comments regarding the metal panelling, learning all the time.
Trev.
#335 Posted : 16 April 2015 21:21:13
Derek,
Thank you Del your comments always appreciated.
Trev.
#336 Posted : 16 April 2015 21:24:48
Hi Alan,
Thanks Alan for looking, my next update will be the Propeller Shaft and motor retainer, looking forward to that.
Trev.
#337 Posted : 16 April 2015 21:26:13
Hi Walter,
Your comments are most welcome thank you.
Trev.
#338 Posted : 16 April 2015 21:33:51
Hi Steve,
Thank you for your comments, sent PM.
Trev.
#339 Posted : 23 April 2015 21:16:25
PROPLLER ASSEMBLY:
230415.
I have assemble the crown and brass screw to the base plate, that seems to be ok, but when I insert the Prop-shaft at the rear of the back plate and then tighten I end up with a small gap of about 1mm.
Is this ok! or am I waiting for a small washer in the next issue, or do I need to correct it by reducing the thread on the brass nut.
Cardboard Packing.
Without the Cardboard packing I have movement.
Thank you for looking.
Trev.
#340 Posted : 23 April 2015 21:36:13
Hi Trev BigGrin
This is perfectly normal and as long as the crown and the brass shaft are of a tight fit then this is correctly fitted.
Your build is coming along beautifully btw Drool
Spencer
Guest (6)
This page was generated in 0.204 seconds.
