Where can I buy some planking-pins? (UK) Options
MadDogMcQ
#1 Posted : 30 March 2010 14:00:11
Anyone know who sells those small brass pins that you use to hold the planking in place while the glue sets?
A link would be helpful.
Tom.
Quentin Tarantino - Hallowed Be Thy Name!
Mike Turpin
#2 Posted : 30 March 2010 14:04:04
philjaps1
#3 Posted : 30 March 2010 14:19:11
Hi thanks for the link Mike - very useful site to know about BigGrin
Allan
#4 Posted : 30 March 2010 16:06:14
I found the push pins that you use on notice boards very handy for this
Allan
jay7792
#5 Posted : 30 March 2010 17:07:48
Allan
+1 BigGrin
_____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
philjaps1
#6 Posted : 30 March 2010 18:21:28
Allan
Nice tip! BigGrin
tomo29
#7 Posted : 31 March 2010 09:28:44
i went to a model last week and i saw in the shop a pining tool with 100 pins for 8 pounds odd
captainpugwash
#8 Posted : 31 March 2010 11:27:25
P & S Hobbies of Walmgate, York, sell the excellent Artesania Latina brass hull pins. Highly recommended!
MadDogMcQ
#9 Posted : 31 March 2010 14:31:41
Thanks guys! Re the notice-board pins, I'd have thought they were a little too thick. No?
PAULS101
#10 Posted : 31 March 2010 18:28:20
Rank: Amateur level 2
yea drawing pins are a bit thick but nice idearBigGrin
Sundance
#11 Posted : 31 March 2010 19:21:16
Re planking pins go to Miskinmodels and get 10 for £9 excellent for clamping planks to each other while the glue dries also ambush the postman and get his strong elastic bands to put around the hull keeping the planks lined up. You'll likely use nails for the first skin, I usually just tap them in until the glue sets then pull them out the mag says nip them off then sand down but this isn't necessary and it's hard work sanding brass! You will receive a plank bender in issue 5 and these are all you need to shape the planks don't buy electric benders: unnecessary. I've built Titanic Victory (Del Prado) and am nearly finished Bismarck (3 years). I crewed victory with scale figures from OnTracks morris dancers! 15 sailors Nelson and a marine officer plus 5 marines. When doing the "ratlines" hold a white card against the mast so you can see the ropes clearly. SundanceBigGrin
Tiswas
#12 Posted : 31 March 2010 21:40:30
Good tips there sundance, but do you mean £9 per 100?
Tarbrush
#13 Posted : 31 March 2010 22:03:38
Thanks for the tip about the electric benders Sundance. You may well have saved me some expense.BigGrin I did wonder as previous boat was done without any benders all be it not very well.LOL I shall suck the benders provided and see.ThumpUp
RussG
#14 Posted : 01 April 2010 03:14:44
Hi There,
Planking Pins !!! most good model supply shop will sell these, google search for best price, personally I think the model shop at the tip of the land is a bit expensive, eh, but thats just my opinion!
But take a look at this pro builder and how he planks! Steve Priske,
Lots to watch and learn!
Russ
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
Allan
#15 Posted : 01 April 2010 09:31:47
Lol not drawing pins the map push pins with the diferent coloured plastic tops as the pin is very sharp and thin with a nice tapered point which pulls the joint tight together
Allan
Mald
#16 Posted : 10 April 2010 18:54:04
Surely you get supplied with some Planking Pins ??? How else do they expect you to build the thing, After all they do show them being used on the DVD , That gave me the impression that we were getting some with the Kit .
Huh Huh Huh Huh Huh Huh Huh Huh Huh
snowtiger
#17 Posted : 10 April 2010 23:34:15
I have seen them on e-bay .....the prices vary ....but they do get deliverd to your door..BigGrin
tomo29
#18 Posted : 11 April 2010 09:43:00
i think we do get the pins when we need them and u get the pin tool in that tool kit with our 3th post of issues
doremi495
#19 Posted : 11 April 2010 12:57:36
I use dressmaking pins (the ones with the coloured tops). The hole left behind is minimal and sanding usually "vanishes" the hole.
Dave H
Current builds :- Hachette 1/16 Tiger Tank
H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
Alexhill
#20 Posted : 12 April 2010 12:22:52
Hi all,
I simply use push pins. I don't push the pins through the plank but adjeacent to it using the flat part on the head of the pin to hold the plank while it dries. In this way I don't end up with any holes in my planks and things seem to end up kind of neat and tidy.
Hope that helps
Alex
Copenhagen 003.JPG (2,852kb) downloaded 70 time(s).
This page was generated in 0.165 seconds.
