Glue on bodywork!!!!! Options
mark8454
#1 Posted : 14 April 2015 08:31:29
Hi all, made a mistake and got glue on the bodywork under the aigo logo, how can I remove it? Pleassse help :(
#2 Posted : 14 April 2015 08:59:59
Hi Mark
Unfortunately you will have to get another issue from the DeaGostini shop unless you want to respray the whole body work.
http://shop.deagostini.c...build-your-own-mclaren/
Spencer
mark8454
#3 Posted : 14 April 2015 09:25:42
I read this online,
does this look like it could harm the silver paint?
Warm, Soapy Water
Mix a few drops of mild soap, such as dishwashing liquid, with water in a large bowl. The mixture should be fairly sudsy. Soak a soft, clean cloth in a sudsy mixture of soap and water, and apply it to the spot where the Super Glue has spilt. Cover the cloth with plastic food wrap, and tape it down so that the moisture does not evaporate. After three or four hours or more, remove the tape, plastic food wrap and wet cloth. Using a dry soft, clean cloth, dab at the spot where the Super Glue is located. Use a blotting motion, and turn the cloth frequently; do not wipe or rub the spot. The softened glue should come up with the cloth. Repeat this procedure if any Super Glue remains until you can remove all traces of it. Wipe the plastic surface dry with a clean cloth.
#4 Posted : 14 April 2015 10:03:59
It might work on unpainted surfaces but doubt it will work on a painted surface. You can but try it, you can always resort to obtaining a replacement.
mark8454
#5 Posted : 14 April 2015 10:22:52
thanks guys
I want to avoid a replacemnt as I have put loads of effort into the main body with decals and carbon fibre detailing
I will try and let you know
#6 Posted : 14 April 2015 10:26:51
Good luck with it
mark8454
#7 Posted : 14 April 2015 10:38:55
Thanks Mr T,
It has brought into question my modelling skills and I am very nervous about the entex mclaren :(
#8 Posted : 14 April 2015 13:09:34
You should not have any requirement to use Superglue for your Entex build as its a polystyrene kit, a liquid poly is best used but still needs the same care of application.
#9 Posted : 14 April 2015 20:03:40
mark8454 wrote:
Thanks Mr T,
I wouldn't let a small mistake like that put you off building the Entex McLaren Mark and after all is said and done, your mistake is on a pre-painted body part whereas the Entex kit is unpainted and any glue mistakes can quite easily be sanded back and resprayed if needs be?
Most people would give their right arm to have a chance to build the Entex McLaren and you have got that chance so grab it with both hands and just think positive, it'll be fine and there is nothing in modelling that can't be fixed with care and patience!! Cool ThumpUp
Kev BigGrin
mark8454
#10 Posted : 14 April 2015 20:11:09
Once again..
wise words from you Kev!!
I will do some touching up bits tonight, i think i will improve it, and it wont be an issue,
the MP4 23 will be finished in 4 weeks and I cannot wait!!
the end is in sight!!
mark8454
#11 Posted : 14 April 2015 23:22:59
By the way guys, it's all sorted now, I was able to touch it up and it's unnoticeable
Thanks Spence, Mr T and Kev!
This page was generated in 0.167 seconds.
