6 Pages «<23456>
Gun Ports..a disscusion Options
Zeptrader
#61 Posted : 06 September 2010 23:12:20
cheers darron and tom, I'll read that a few times just to understand it better, was never that happy with figures, but I understand the logic.
So in theory the plans you posted are in 1/48 (taken from McKays book), if I measured these or other plans in the book and again change the scale I could convert that to our scale in 1/84? with a workable measurement of mm or cm?
Son of Bulwark
#62 Posted : 06 September 2010 23:43:46
Spot on Colin,I'll send you an email tomorrow with the speadsbeat attached ok!.
Darron
jeff averre
#63 Posted : 07 September 2010 00:59:21
I'm not as far on as everyone else, (still waiting for 19-22), so I've plenty time to consider the gun port problem.
As I've not yet added the second deck I'm thinking of leaving it until I've cut & lined the gun ports, if I do that I will make the linings up (like a box section) and fit them from the back and glue them to the rear of the planking after painting them and get the rebate by making the box section hole about 8mm.
This is my first build for nearly 40 years so I'm looking to make things as easy as possible without lowering standards, as mentioned earlier and in other threads 'plans' would be an enormous help, why can't 'De Ag' provide part plans every 2 or 3 months to help us prepare, as I've mentioned before it could save us 'painting ourself into a corner' or may be buying extra stuff needlesly!
Before I go I would also like to add my thank's to everyone for a cracking 'Thread'.
LOL BigGrin BigGrin
Jeff
piot007
#64 Posted : 07 September 2010 09:08:30
Jeff
This method sounds very straight forward to me. Luckily I'm at the same stage as you.
I haven't even glued any of the main hull, just dry fitted it all together.
Im now over how awesome it looks, even at this stage, and now i want to get gluing.
I'm glad i saw this before i started.
Maybe you could also simply glue a larger square of scrap 1mm thick sheet which is 11x11mm inside by 14mm sq outside.
Making squares, with sq holes, with 2/3 mm thick sheeting instead would give you the edge/space for hinges for traps/coverings/lids. other details (hooks for lamps)
Any thicker may look out of scale.
I will use that excellent post by Darron to see it on paper.
#65 Posted : 07 September 2010 10:57:25
colin,darren,As I've said earlier ^ , I thought long and hard,so.gunports here we go, I'm going to to do mine like this,(pics to come,)I'm useing 3mm. x 1mm. lime.the lintils going right across from 1 bulkhead (rib,frame) to the next,slightly proud of the outer skin,so that I can sand them flush for the planking,and level with the gunport cutout,and the same with the sill,then the sides are added next,then I will paint the gunport frames red ocre,then apply the planking,and then cut out the gunports,now when we are supplied with the gunport lining materials I can just add it the frame,which now has support and can be pushed in further to creat a rebate(rabbit).if you can see any flaws in this method,let me know.the gunports will have to be moved over by 1mm. for this method so the down piece nearest the frame can be inserted and be flush with the gunport cut out.
#66 Posted : 07 September 2010 15:52:36
I've started the sills first,change my mind and used 5mm.x 1mm. lime instead of 3x1mm.that was darren calculation of scale size.
#67 Posted : 07 September 2010 15:55:58
now the lintels and uprights are added,using a jig like what tom used.
#68 Posted : 07 September 2010 15:58:06
I can see some upright too far forward,will adjust later.
Son of Bulwark
#69 Posted : 07 September 2010 17:52:52
Hi Karl! BigGrin
Don't forget that as you go up from one deck to another you will need to reduce the size of the gunport lining's 5mm for the lower gundeck, 4mm for the mid gundeck and 3mm for the upper gundeck. As the gunport lining fits between the outer planking and the inner planking, following the shape of the ribs which got thinner with each deck.
ThumpUp Darron
Zeptrader
#70 Posted : 07 September 2010 18:21:59
This is what I had in mind.
I wonder if this way would be better, it would allow the shaping of the gun ports a little better. And then plank around the ports.
#71 Posted : 07 September 2010 21:17:06
yes colin I like the 1st pic nice and heavy,and robust,thanks darren for that info.will take note,I feel i'm getting somewhere now,will redo in heavier wood.
Mr.Quist
#72 Posted : 07 September 2010 21:28:56
To all those experienced ship builders out there:
Whould this type of brass frames of any good for the gunport problem?
Found in a German Modelshop and at
Cornwalls.
Greetings, Mr.Quist
My build diary here
HMS Victory
Jack Sparrow
#73 Posted : 07 September 2010 21:31:57
Mr.Quist wrote:
To all those experienced ship builders out thers:
Cornwalls.
Greetings, Mr.Quist
MMMMMMMMM now there is a thought!!!Love Well done sir!!!!BigGrin
Zeptrader
#74 Posted : 07 September 2010 21:51:23
I've just had a quick look at McKays book on page 86 diargam D7 as shown earlier in this thread, showing the entry port and side ladder, this also shows the 3 gun ports from lower deck to middle and top.
Using my new digital callipers Ive measured the lower gun port (the scale of the drawing is 1/48, using Darrens excellent excel document these are the figures Ive got.
width in 1/48
22.89mm (rounded to 23mm) converted to 1/84, which makes 13mm
Height in 1/48
19.78mm (rounded to 20mm) converted to 1/84, which makes 11mm
now to check I'm on the right path (maths and numbers were never my strong point)
width in 1/192
5.39mm converted to 1/84 = 12.32mm
height in 1/192
4.84 converted to 1/84 = 11.06mm
so that would make on average the gun port size for our ship is 13mm x 11mm..yes, no?
reading Jotika's instructions it mentioned the gun ports of the lower decks and middle decks as having 1mm deep lip, the upper deck ports have no dip and are smaller in size.
Son of Bulwark
#75 Posted : 07 September 2010 22:17:18
Hi Colin! BigGrin
You have got to grips with the spreadsheet, your right the gunports aren't square. So what will the lids be? I bet we'll have to make them the right size or we'll have to put-up with another error.Mad
Darron
Zeptrader
#76 Posted : 07 September 2010 22:32:43
Cheers Darren, I think the lids will have to be made to what ever size the individual builder has made there gun ports, I don't see it being a massive problem.
looking at the diagram (D7) my measurements were made including the surround, not the inside, so maybe a little smaller than 13x11.
To be honest we are talking almost 1mm, not going to be noticed by many BigGrin
So for me I will sleep on what I want to do, which is probably cut to the size of the gunport lid and add the framing to that size.
The more I think on this its all down to personal choice if you want to move away from the official build but use the stock given in each issues and create the hull to a more authentic state or keep with the main official build, either way I don't think any one of those is wrong.
willz
#77 Posted : 07 September 2010 23:40:13
Thats the size I get it to Colin, I do use a spreadsheet for some calculations but from 1/48 to 1/84 you can simply use a calculator i.e. The source measurement multiplied by 48 divided by 84
One other point, when rounding figures always do it at the end of all the calculations
Zeptrader
#78 Posted : 08 September 2010 07:12:34
thanks Willz, I didnt know that so very helpfull, Im glad you got the same sort of figure, I will be re doing those calculation but converting them into /16 and /32, I made a paper scale convertor some years ago and found this way gives me the full measurment and no need to round the figure up.
Just used you suggestion on the calculator and it works, didn't know that either, thanks again mate.
Now to get the correct position of the gun ports on the lower deck, I'm sure its pretty much where the official build suggest but worth having a look anyway.
Zeptrader
#79 Posted : 12 September 2010 00:22:57
Just found a guy making the Victory from scratch, and his approach on the gun ports framing.
Zeptrader
#80 Posted : 12 September 2010 08:43:46
A few more AL build pictures from MSW, I'm sure they will help understand how and what goes where.
Notice the gun port near the bow, this is where a few people have put fillers, including me!!
Also worth noting is the first picture shows the gun port lining, as I thought, different colour stock and possible 1mm, which then reduces the port size perhaps to 11mm square.
6 Pages «<23456>
This page was generated in 0.489 seconds.
