Anchor Binding Options
Wilberforce
#1 Posted : 07 September 2010 14:43:14
Hey guys
I have read alot of the posts about the anchor and you guys are really finicky about the anchor detail - not that that is a bad thing LOL My query is this, if we are to use the cotton to act as the metal bindings on the anchor, how many turns should we make,the build instruction says when you have enough turns, how many is enough? I am thinking of trying a different approach as you guys are but haven't made up my mind yet. I like the idea of tape but I am not completely comfortable with this approach because the tape sometimes has a tendency to lose its stickiness and come loose, that would be terrible in time. I might use cat5 cable housing if it isn't too big in circumference.
Thanks
Current build : The Victory
Pending builds : none - yet
Built loads of bikes trucks planes and boats - all plastic kits.
on wish list - a 1:24 spitfire, in wood, plastic, just as long as I can build it :)
riff-raff
#2 Posted : 07 September 2010 14:49:16
For me it's a "Look" thing. I cut the supplied thread into 4 equal parts and wound each length around the anchor, but it didn't "Look" right so I added some more that I had from a previous build.
A lot of what people do here is a personal thing where others are more concerned with acuracy - each method works for each individual.
Not sure about your cat5 cable housing but if you feel that it "Looks" right then it's right.
Built:
Wilberforce
#3 Posted : 07 September 2010 15:02:32
Thanks Riff-Raff
I gathered the personal choice thing with the build - I haven't actually decided what I am going to do yet, want to think about it before I stuff it up. Was the binding on the real thing a solid ring or was it bounds of cable? Do you know?
ArtfulBodger
#4 Posted : 07 September 2010 16:21:50
Depending upon the effect you want, then either try about 4/5 mm width of various bindings or try copper banding. Having taken about 700 pics Jase is probably your man.
ArtfulBodger
Previous Build:
HMS. Bounty
willz
#5 Posted : 07 September 2010 16:50:33
Wilberforce wrote:
Thanks Riff-Raff
They were solid steel bands, and they were knocked down the taper of the stock until they were tight to hold the two halves together
Wilberforce
#6 Posted : 07 September 2010 18:20:49
OK my anchor build is done, well the 1st 1 at any rate. I have in by pipe box black waxed hemp, it is waxed so can be flattened. Bound the brass ring with the hemp to give it a ropey appearance. Took super glue and a cotton ear bud and stuck some of he cotton wool to the hemp to give it worn look. Looks good but the puddening looks a bit big but it looks good anyway. I then bound the anchor ribs with the hemp, again pressing it flat and just touching up with some black paint. looks pretty damn good. Will try post a photo
doobeiferkin
#7 Posted : 07 September 2010 22:05:21
Rank: Beginner Level 3
I originally used hread to simulate the bindings for the anchor (as described in the magazine). When I saw the real anchor and realised it was all black I painted my anchor but the bindings did not good and you could see they were thread. I cut them off and made some hoops from brass stips from my local model shop. I think the end result was worth the time and effort and I will use this methods for the remaining anchors.
Mike Turpin
#8 Posted : 09 September 2010 21:58:35
Hi All
The bands round the anchor were forged metal bands, which were heated and then allowed to contract round the anchor, in the same way as barrel hoops are fitted.
My solution was to use 160gm/m2 card and simply cut thin strips which I super-glued on. I then painted the lot with black paint.
Mike T
Boaz
#9 Posted : 09 September 2010 22:33:48
Hi guys.
I used 4 pieces of thin card & it worked a treat.
I cut them from the card that my wet & dry was in.
Just a nice thickness.
Bob
willie
#10 Posted : 12 September 2010 15:31:58
how to get a nice tight binding i tried heat shrink it worked out ok 1/8" strips
tking
#11 Posted : 13 September 2010 16:50:00
Rank: Newbie
Likewise, I used black heatshrink and then black gloss paint to simulate metal. You get the thickness from the heatshirink and can cut to desired width. Care when applying heat not to scorch wood
willie
#12 Posted : 13 September 2010 17:01:24
quick splash of boiling water is better than a flame
Dontshootme
#13 Posted : 13 September 2010 17:05:20
Where can you get the heatshrink from?
Lonestar Spirit
#14 Posted : 13 September 2010 17:11:47
I think Maplin sell heat shrink, not that expensive too.
Cheers for the info mate, well appreciated
Best Wishes
David
Ship Builds on the go
willie
#15 Posted : 13 September 2010 19:02:34
heatshrink 8mm inside dia from cornwall model shop £1.21p for 250mm is the size to fit the stock up at the anchor shaft anny smaller may have trouble fitting, shrinks down to 3mm dia with boiling water
This page was generated in 0.208 seconds.
