5 Pages <1234>»
Budgies Bismark Options
Ken
#21 Posted : 06 April 2015 13:03:37
Hi Budgie
Bismark looking good. will be following with interest.
Ken
Completed Models
IJN Yamato, Hachette Titanic, Del Prado Victory, Tamiya 1/16 RC Pershing Tank, HMS Naiad, HMS Prince of Wales, Admiral Hipper, Tirpitz, USS North Carolina
[Current Build
USS Enterprise CV6
#22 Posted : 06 April 2015 22:35:05
great to see this up and running will follow with interest
P.S. I am the last person to notice this but, Bismarck is spelt with a 'C' before the K
J
budgie
#23 Posted : 08 April 2015 20:44:58
BigGrin Evenin' Folks
Huh Decided to deviate from instructions Blushing Uh Oh Blushing
Instructions want me to strengthen the hull planks by using surgical gauze and white glue next and then fit the forward deck and then finish off the planking to the top off the frames
I have decided to plank to top off frames 1st this will allow me to strengthen ALL the hull planks
Blushing Used a felt tip to colour in the top off the frames this will tell me when to stop sanding Blushing Hopefully
LOL Thinking pink is a bit girlie changed to blue
Crying I have noticed that the ledge that starts to replicate the armour plating is virtualy unnoticeable that runs along the hull
This is probably due to not enough care taken when sanding the frames and 1st planking
The 2nd planking is very thin and after sanding will again just look like a bad crease
I am hoping that when the time comes using a thicker plank along that line will help rectify this issue
budgie attached the following image(s):
#24 Posted : 08 April 2015 22:21:23
Looking good budgie, keep them coming Cool
#25 Posted : 08 April 2015 23:54:39
She's certainly progressing really nicely, impressive work so far Budgie... Very well done...Drool Drool
#26 Posted : 09 April 2015 13:07:43
Hi Budgie.
Doing a fantastic job so far.
The answer to some questions regaurding the decks in your post earlier.
The middle section from the bow to the rear gun turrett is removable on the redaio control version and there is a removable stern quater piece.
These are held in place on the model by four screws in each section, They are the only differnce to the static version.
The deck sections are stuck on to ply type sections you can hardley notice the joins. The decks are removable to acess the radio gear in the model. The gause and glue you mentioned for strenthening are more for the radio comtrol version of the model where the rudder tubes go trouth the hull i think this is more of a water proofing method for the inner planking in case water comes up the rudder tubing wihich are filled with grease.
Hope this helps with your questions. you can see some pictures in me Bismark build. Ian
#27 Posted : 09 April 2015 13:24:49
budgie
#28 Posted : 09 April 2015 17:45:04
BigGrin Thanks for comments guys ....appreciated
@ Ian
BigGrin Took me a while to find your build diary...been some time since your last post
Just wondering if there is a noticable line in the planking where the middle deck lifts off hence my reason for thinking off making the superstructure removable instead... once all the thingies that makes it go are in place
#29 Posted : 11 April 2015 14:06:05
Hi budgie have taken some pictures of the deck joins for you. Hope this will help with your thoughts.Ian.
budgie
#30 Posted : 11 April 2015 17:13:06
BigGrin Cool Thanks for taking the time & effort Ian appreciated and the pics has satisfied my curiosityCool
budgie
#31 Posted : 11 April 2015 18:03:13
BigGrin Hi Folks Crying made a boo boo
1st pic shows a slight bend in planking which is correct Cursing but only on one side...Blushing silly me
2nd pic shows this rectified by loosening the top two planks and gluing a bit of planking to a couple of the frames to make them wider to push planks into the bend
Cool Have started strengthening the planking using gauze and diluted wood glue as per instructions
Cool Have also glued the forward deck on and keeping it in place with use of elastic bands
Blushing There is a slight gap between the deck and last row of planks which i will fill in with putty later
Cool Also glued my first resin piece
Instructions recommend 2 part epoxy but the tube of "serious glue" has done the job. BigGrin That part aint going anywhere
I hope it is as good as sticking brass to wood and i do not relish the idea of using epoxy for all those parts
Crying Ah well back to the gauzeing
Thanks for lookin'
#32 Posted : 11 April 2015 18:07:28
Nice work Budgie, shame about the boo boo but by the look of the pictures you do a great job rectifying it so its all good Cool
budgie
#33 Posted : 19 April 2015 12:14:53
BigGrin Mornin' Folks......been plodding along with the false deck
Blushing Have noticed that if you do not clamp the strips together, the ply sides that has the shape of the deck can overlap the hull by quite a bit
Cool I suppose if you sand the inner edge this will rectify the issue as you do not want to sand the outer edge in case the shape gets distorted
LOL Pity i never thought of that before redoingLOL
Cool Also made a start on the 2nd planking using the same thickness off planks as the 1st planking (from the "spares") so the armour plating ledge is more noticeable
Confused Was concerned about doing this as there are thinner detailed parts to be added to the hull (ply with portholes) but a test fit seems tiddlyboo BigGrin
Laugh Getting bored with the planking so started the big gun turrets Anton Bruno Cesar and Dora
Thanks for lookin'
#34 Posted : 19 April 2015 14:41:21
Hi Budgie, BigGrin
Looking good. Cool Cool
Good job you noticed the little hiccup when you did, but nicely corrected.
Keep on the way you are going and you`ll end up with a cracking build.
#35 Posted : 19 April 2015 14:43:43
BigGrin Very nice workCool Cool
budgie
#36 Posted : 20 April 2015 20:44:37
BigGrin Thanks for the positive comments chaps....appreciated
Crying Back to the planking
The "cooling water openings" are to be placed 9 rows of 5mm planking down
Cool As i am using 6mm wide planks i only need 7 rows Flapper Yippee
Crying and a half Blink
#37 Posted : 20 April 2015 21:46:17
BigGrin looking good there, nice workCool
#38 Posted : 21 April 2015 00:21:49
Lovely work Budgie, think she is going to look something special when done....Cool Cool
#39 Posted : 21 April 2015 08:16:09
Great work Stuart, love the ship. It's a credit to u mate and look forward to the progress of the build.
#40 Posted : 22 April 2015 14:37:58
Hi Budgie.
Looking superp. have you decided which paint scheme you are going to do when you get there. look forward to seeing your progress IanCool Cool BigGrin
5 Pages <1234>»
This page was generated in 0.258 seconds.
