2 Pages <12
Mavricks Victory Options
Son of Bulwark
#21 Posted : 26 March 2012 22:35:22
Hi Steve! Cool
You need to reduce the last ribs to match the angle of the false keel, it isn't you that's the way the ship is made most of the last ribs get filed or sanded off.
If the keel is 2mm in at the top, the transom thickness needs to be reduce 2mm at the top and if it is 6mm in at the bottom then again reduce the transom 6mm at the bottom.
It is very important to get the stern right the transom needs to be flat to the false keel or the rudder won't fit.
Darron
mavrickandgoose
#22 Posted : 27 March 2012 02:16:57
Cool, cheers for the advice guys, I will get that sorted asap. Thats why this forum is great, you can get mistakes pointed out and rectified before its a real problem!
Thanks again
steve
mavrickandgoose
#23 Posted : 04 April 2015 21:44:00
So nearly three years to the day I last touched my Victory I have started it again. With much encouragement from my wife. So here are a few picks of the planking i have been doing over the last few days. Just waiting now for my new knife with some very sharp blades to be brave and cut out the gun ports.
[/URL ][URL=http://s804.photobucket.com/user/mavrickandgoose/media/HMS%20Victory%20Model/11082556_567618666712308_6567977000820101412_n.jpg.html]
#24 Posted : 04 April 2015 22:33:13
BigGrin Glad to see your back on her, the ports will get easyer as you do more just measure everything at least twice before you cut and you will be fine.Cool
#25 Posted : 04 April 2015 23:59:01
Great to see you've got the bug again and are back working on the old girl... Lovely work to date, looking forward to seeing more and good luck cutting those gun ports out....Cool Cool
#26 Posted : 05 April 2015 00:22:18
2 Pages <12
This page was generated in 0.202 seconds.
