5 Pages 123>»
Budgies Bismark Options
budgie
#1 Posted : 04 April 2015 08:47:33
BigGrin Mornin' Folks
Browsing ebay over the Xmas period i came across Hachete's partwork "Build the Bismark" all 140 issues Drool unopenedDrool
A deal was struck and completed and i recieved the goodies in good time
Cool I wisely decided not to start the build until after the Hogmany celebrationsBlushing
During this time i opened all the issues and only found one setback
Crying One of the antiaircraft guns moulding was not complete
A search for back issues on ebay was not successful for the one issue i required
But i did come across someone who was selling spares and one of the photos showed the items i required.
So now i have a complete kit and spare decking and plastic fittings
The parts are the usual ply and various types of wood for the hull and superstructure and main gun frames etc
Brass is used for superstructure/main guns walls
Bored There is a lot of plastic parts which at first glance i thought was a bit naff (Deags Yamato/Akagi are metal)
But on reflection once painted who can tell what material they are made off......but mainly.. as the model can be converted to R/C i have convinced myself the main reason is to keep the weight down to prevent her becoming top heavy
budgie attached the following image(s):
#2 Posted : 04 April 2015 09:24:42
Lucky boy getting hold of this kit.... Hope to be able to follow this one on a diary, always great to see another Bismarck come together....Cool Cool . Good luck Budgie, look forward to your next update....Cool Cool
budgie
#3 Posted : 04 April 2015 09:43:45
BigGrin Hi Allan thanks for lookin' in
Despite this partwork ending a few years ago the Bissie seems to pop up on ebay on a regular basis...and a great bargain can be made
As this model has mouldings for the pointy end and the bow it can be a good intro to planking the hull as no drastic bending off planks at he ends
http://www.ebay.co.uk/it...amp;hash=item2c9924a9b4
budgie
#4 Posted : 04 April 2015 09:53:29
BigGrin On with the build....Drool wanna do the big gunsDrool but
Despite the parts being several years old there does not seem to be any warps on the flat keel but it is not as tight a fit as expected allowing slight movement
So using a straight line on the build board and dry fitting the frames and supports out comes the glue
#5 Posted : 04 April 2015 10:22:41
Oooh nice, looking forward to seeing this come together.
I will be watching that ebay link with great interest Cool
#6 Posted : 04 April 2015 10:57:43
BigGrin Nice start on her and are you going for the static or R/C versionCool
#7 Posted : 04 April 2015 10:57:44
Titanic5972
#8 Posted : 04 April 2015 12:39:05
I thoroughly enjoyed building this model. Looking forward to seeing your progress.
On the Go
RMS Titanic 1/250 (third time)
Completed
RMS Titanic 1/250 (twice), DK Bismarck 1/200, RMS Queen Mary 2 1/400, HMS Hood 1/200
budgie
#9 Posted : 04 April 2015 15:56:32
BigGrin Thanks for comments guys
@ARPurchase...i am humming and hawing over conversion to R/C
LOLFirstly i will need to make sure my build is suitable to be seen in daylight
My other issue is that at the moment the instructions say that the middle deck is removable for access..
Confused Will that mean that the deck planking will have a noticable gap straight across the deck at those two points
Cool Am thinking that access may be available by removing the superstructure parts instead
Cool Food for thought
Anyhoos no sign of the big guns yet...onwards with the frames
They all seem to square up nicely together
budgie
#10 Posted : 05 April 2015 08:11:40
BigGrin Mornin' Folks....Happy Easter
Crying Time to body swerve the planking and start the big guns mmmmmm
Confused The instructions for planking tells me to lay the planks parrallel to one another not staggered like we are used to
I almost swayed from the instructions and stagger the planking .......
but realised this is how the designers want us to do it.....
Huh Where the ends of the planks rest the frames are twice as thick
Huh The inside of the hull is to be covered in gauze and glue
Huh The 2nd planking is staggered
A problem did arrive several strips down which you can see in the picture
I felt too much effort was require in order for the plank to be pinned and glued to the previous laid plank
Letting it lie naturally leaves a gap to be filled....but there is no space on the frame on which the ends can rest
Maybe it would not matter as the inside is going to be strengthened and an outer layer of planks will be added later
Tapering both ends of the plank seems to have resolve this issue as i can now lay the plank against the previous laid one without much effort and the next plank requires no adjustment
BigGrin Woo HooLaugh
#11 Posted : 05 April 2015 08:32:23
BigGrin Coming together nicely, shaping the plank is the best way to solve that little problem you could also have planked around it letting the upper planks lie as they want and then filling the gap left with a shaped plank.Cool
#12 Posted : 05 April 2015 10:51:30
Looking great Budgie, lovely work.... Cool Cool .. I did have a look at that link on Ebay you provided but unfortunately seller won't send, pick up only and it's too far for me to travel... Had to let it go I'm afraid...Cool Cool .. Still, I'll enjoy following your progress none the less....
budgie
#13 Posted : 05 April 2015 11:08:12
Hi Alan
My purchase was pick up only as well
A courier picked it up from the seller way down south at 0900
Picked it up at my local PO (spar shop)next day
Lady said it had been delivered previous PM
Drool All 140 issues in a taped up cardboard box
Only cost About a tenner via online courier service
Might be to your advantage to pm the seller and ask if a pick up from a courier is acceptable
AndreZS1AZ
#14 Posted : 05 April 2015 11:10:44
Hi Budgie, it's looking good. I started the same build when it came out as a part work here in South Africa. I have done the first planking of the hull and did some steaming to get the bends correct. It is now on the back burner due having built a rc PT boat and I am now busy with the final stages of my hydroplane. Enjoy the build.
It's not the fall that kills you, it's the sudden stop
Building: Bismark, 2.5m wingspan glider
#15 Posted : 05 April 2015 14:46:19
Its looking great Budgie
budgie
#16 Posted : 05 April 2015 19:26:00
BigGrin Thanks for nice comments chaps
Mellow The gaps slowly getting filled in
budgie
#17 Posted : 05 April 2015 21:14:01
BigGrin Well thats it Folks
Cool Build diary now up to the stage i am at with the model
1st planking sanded and a layer of filler was spread all over the hull and slowly sanded to a smooth finish
BigGrin Thanks for lookin'
#18 Posted : 06 April 2015 00:12:31
Very nice indeed, lovely work.....Drool Drool
#19 Posted : 06 April 2015 10:37:54
Looking Excellent there Stuart Drool , very Jealous as I would have loved to have the bizzy next to my Hood. I'm looking at the Trumpeter Bizzy now as its hit and miss if hatchette one turns up on ebay.
budgie
#20 Posted : 06 April 2015 10:55:32
BigGrin Thanks for lookin' Chris
Drool Have been watching your Hood coming alongDrool Drool
The below link for Bismark has only 8 hours left to go
The ones i have watched previously have been going at the £300 mark
Down side is seller will not post but sure will allow a courier to pick up
Cool How hard is it to shove all the issues in a cardboard box and stick a sheet of paper with address on it
ps i have no ties with the sellerLOL
Drool Just a great bargain maybe had for someone to enjoyDrool
Might not be long till the Hood starts appearing on ebay
5 Pages 123>»
This page was generated in 0.636 seconds.
