 Hi All Starting shortly my build will begin on here. I will be doing some small mods but nothing too fancy as I think she is a great model as she is. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice one Andy, I'm sure you'll do this fine model the justice it deserves - well done!!
Kev
 Hi Kev Thanks for looking in and your comments, this is one I have fancied for a while now. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice choice Andy, looking forward to seeing what ideas you have for it. You got a few on the go now then Steve
 Hi Steve thanks for looking in and your comments, as iv already said I wont be doing to much on the mod side on this one just small enhancements where there needed if at all as I think the detail on this as it stands is top notch anyway. I know many are doing there own enhancements and that,s fine with me I just feel this is one kit that stands on its own as she is supplied. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All I have been collecting this for ages now and so I have several packs and iv been a little too busy to start until now, so here goes. Pack 1, no major issues here everything went together like a dream just needed to grind a couple of mil off the rear screws holding the fin's on as they stuck out a little too much from the tab for my liking. I have drilled out the Brake disc and will probably add a wash later. I have found the tyre good year prints to be on the fragile side and easily scratched so I will replace those. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Pack's 2-6. Made up the clutch and inked as needed and mounted on engine block made up two hubs and fitted the disc's and calipers rear wing was made up and the lower nose and wooden wing skids added,alternator was made up along with the plenum chamber. Left and right radiator housings have been assembled along with the radiators also the battery and solenoid panels made. Rear wheel assembled and the side panels added to the monocoque and lastly the two turbo intakes have been assembled. All the radiator's and grills have been inked as have the engine and brake calipers, must say im enjoying this build, more soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
A nice start to your build Andy and very nicely presented. Excellent work - well done.
Kev
 Hi Kev Thanks for looking in and your comments Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Packs 7-9. Made up the rear mono plate and the front shock absorber's and finished off the right radiator housing, inked the shocks and struts then made up the cockpit. made up the front shock plare assemble and added the front mono end plate. Fixed the head plate and rear plate to the mono then made up the front underfloor and brake/clutch reservoir's and added the steering assembly. Added the front plate and the reservoir's/brackets. Assembled another tyre/wheel then added the left wishbones and front hub,glued the cockpit in place then added the tube to the battery on the left radiator housing then the right front suspension was added. Again everything went together without any issue's although i know some of you have had problems stretching the tube ends, using a tooth pick as recommended in the instructions didnt work for me so I used the point of a pair of tweezers to stretch the tube and it worked fine as long as your quick to fit it in place. more soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good. You're knocking this out quickly! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Hi Steve Thanks for looking in and your comments, I have up to pack 11 so after that's done Il be waiting like everyone else for parts to arrive. More dreaded tubing/pipework to be done now  . Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
More great progress Andy and looking good - you seem to be building this car almost as quick as Senna was able to drive it!!
Keep up the good work Andy.
Kev
I'm at the same point as you, waiting for pack 12. And yes them tubes are a nightmare and there are more to come! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
This has to be my personal favourite due to the detail offered as a kit of this size and great to see another build diary Andy. Spence
Sorry Andy, have just noticed you have started this build and an excellent start you have made too..  .. I'm not a great car fan but I do love the detail these kits have to offer and may be tempted to have a go one day....  .. Will be following from here on in though, keep the pics flowing.... Regards Alan
 Hi Kev thanks for looking in and your comments things will slow down to normal now as I have reached the end of my stored packs at pack 11. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Steve thanks for your comments I seem to be doing ok with the tubing using the tweezers to pre-stretch them its working for me anyways. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Spencer thanks for looking in and your comments I have to agree with you about it being a favorite to me this car is a classic Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Alan no need to apologize as there,s so much going on its easy to miss posts, Thanks for looking in and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
