4 Pages 123>»
Andy's Senna MP4/4 Build Options
#1 Posted : 01 April 2015 22:04:42
BigGrin Hi All
Starting shortly my build will begin on here. I will be doing some small mods but nothing too fancy as I think she is a great model as she is.
#2 Posted : 02 April 2015 12:41:49
Nice one Andy, I'm sure you'll do this fine model the justice it deserves - well done!! Cool ThumpUp
Kev BigGrin
#3 Posted : 02 April 2015 19:22:32
BigGrin Hi Kev
Thanks for looking in and your comments, this is one I have fancied for a while now.
#4 Posted : 02 April 2015 19:24:42
#5 Posted : 03 April 2015 00:28:33
BigGrin Hi Steve thanks for looking in and your comments, as iv already said I wont be doing to much on the mod side on this one just small enhancements where there needed if at all as I think the detail on this as it stands is top notch anyway. I know many are doing there own enhancements and that,s fine with me I just feel this is one kit that stands on its own as she is supplied.Cool
#6 Posted : 03 April 2015 11:40:33
BigGrin Hi All
I have been collecting this for ages now and so I have several packs and iv been a little too busy to start until now, so here goes.
Pack 1, no major issues here everything went together like a dream just needed to grind a couple of mil off the rear screws holding the fin's on as they stuck out a little too much from the tab for my liking. I have drilled out the Brake disc and will probably add a wash later. I have found the tyre good year prints to be on the fragile side and easily scratched so I will replace those.
#7 Posted : 03 April 2015 21:16:10
BigGrin Hi All
Pack's 2-6. Made up the clutch and inked as needed and mounted on engine block made up two hubs and fitted the disc's and calipers rear wing was made up and the lower nose and wooden wing skids added,alternator was made up along with the plenum chamber. Left and right radiator housings have been assembled along with the radiators also the battery and solenoid panels made. Rear wheel assembled and the side panels added to the monocoque and lastly the two turbo intakes have been assembled. All the radiator's and grills have been inked as have the engine and brake calipers, must say im enjoying this build, more soon.
#8 Posted : 04 April 2015 11:30:47
A nice start to your build Andy and very nicely presented. Excellent work - well done. Cool ThumpUp
Kev BigGrin
#9 Posted : 04 April 2015 21:45:25
BigGrin Hi Kev
#10 Posted : 04 April 2015 22:24:13
BigGrin Hi All
Packs 7-9.
Made up the rear mono plate and the front shock absorber's and finished off the right radiator housing, inked the shocks and struts then made up the cockpit. made up the front shock plare assemble and added the front mono end plate. Fixed the head plate and rear plate to the mono then made up the front underfloor and brake/clutch reservoir's and added the steering assembly. Added the front plate and the reservoir's/brackets. Assembled another tyre/wheel then added the left wishbones and front hub,glued the cockpit in place then added the tube to the battery on the left radiator housing then the right front suspension was added.
Again everything went together without any issue's although i know some of you have had problems stretching the tube ends, using a tooth pick as recommended in the instructions didnt work for me so I used the point of a pair of tweezers to stretch the tube and it worked fine as long as your quick to fit it in place. more soon.
Steve279021
#11 Posted : 04 April 2015 23:25:33
Looking good. You're knocking this out quickly!
Dodge charger build complete
#12 Posted : 05 April 2015 08:40:51
BigGrin Hi Steve
Thanks for looking in and your comments, I have up to pack 11 so after that's done Il be waiting like everyone else for parts to arrive. More dreaded tubing/pipework to be done nowBlink Blink LOL Crying Crying .
#13 Posted : 05 April 2015 10:36:15
More great progress Andy and looking good - you seem to be building this car almost as quick as Senna was able to drive it!! Blink Cool ThumpUp
Keep up the good work Andy.
Kev BigGrin
Steve279021
#14 Posted : 05 April 2015 10:39:22
I'm at the same point as you, waiting for pack 12. And yes them tubes are a nightmare and there are more to come!
#15 Posted : 05 April 2015 10:50:04
This has to be my personal favourite due to the detail offered as a kit of this size and great to see another build diary Andy. Cool
Spence
#16 Posted : 05 April 2015 11:01:41
Sorry Andy, have just noticed you have started this build and an excellent start you have made too..Cool Cool .. I'm not a great car fan but I do love the detail these kits have to offer and may be tempted to have a go one day.... Cool Cool .. Will be following from here on in though, keep the pics flowing.... Cool Cool
#17 Posted : 05 April 2015 16:46:06
BigGrin Hi Kev thanks for looking in and your comments things will slow down to normal now as I have reached the end of my stored packs at pack 11.
#18 Posted : 05 April 2015 16:49:52
BigGrin Hi Steve thanks for your comments I seem to be doing ok with the tubing using the tweezers to pre-stretch them its working for me anyways.Cool
#19 Posted : 05 April 2015 16:53:25
BigGrin Hi Spencer thanks for looking in and your comments I have to agree with you about it being a favorite to me this car is a classicCool
#20 Posted : 05 April 2015 16:56:08
BigGrin Hi Alan no need to apologize as there,s so much going on its easy to miss posts, Thanks for looking in and your commentsCool
4 Pages 123>»
This page was generated in 0.272 seconds.
