Engine Removal Options
Ford62
#1 Posted : 31 March 2015 22:25:34
Hi All
I was Halfway through breaking in my engine when the starter cord snapped so I removed the engine to install a new Pull Starter, I have decided not to put the engine back in at this stage as i will have to pull it out again to install the Gearbox upgrade. (Completed Issue 100)
Is there anything I need to do to the half run in engine while it is off the Car apart from clog carb intake etc.
Will the engine be affected by only being half run in??
Thanks Guys any input would be appreciated.
#2 Posted : 31 March 2015 22:50:01
Loosen the glowplug, then apply a few drops of after-run oil into the cylinder, manually turn the flywheel a few times to coat the internals then leave so that the piston is at its bottom dead centre, also remove any fuel from the tank.
This page was generated in 0.079 seconds.
