After a lot of trouble, getting the right shipments and also the right building instructions - i finally could give the Spitfire a start.
Despite looking very straight forward - i found the building of the rear fuselage quite challenging. The first try there was a bending to one side, so i had to dissassemble.
The second time i built some kind of jig - i hope now everything is correct!
DaDokta attached the following image(s): Greetings, Walter
Looks like you are off to a great start...  Will be following your progress...... Regards Alan
Hi DaDokta, Glad to see you got sorted. I had the same issue and sorted it with clamps. A tricky bit of the build if you don't keep your eye on the ball. You'll be able to carry on now with renewed vigour. Can't wait to see more Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi maty, good to see another Spit under way. all looks plumb now looking forward to following your build Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Thanks for your comments Alan, Derek, Jase!Greetings, Walter
Hi DaDokta, Looks a good build to me, that rear fuselage was a bit tricky pleased to see you have overcome it and continue to build, I have found that you will get small problems but easy to overcome, all the best for now and keep posting. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Nice to see another Spit on the go Doc.. Looking good so far and it's a big beasty Spencer
After 3 months the third shipment finally arrived and i could make some progress with my Spitfire-build:DaDokta attached the following image(s): Greetings, Walter
Joined: 01/10/2013 Posts: 28 Points: 74 Location: Ilford
Nice Neat build there DaDokta :) Raven(Colin) Building: DeAgostini Spitfire V5b, HMS Victory & Cross section, Hachette Black Pearl In the Stash: Fine Molds 1:72 Millenium Falcon, Trumpeter 1:16 King Tiger Completed: Eaglemoss 007 Aston Martin DB5, Dragon 1:9 The Avengers Iron Man Mark VII
Hi Dadokta, Very nice clean build wish you well with this build. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Great work DaDokta, its really coming along nicely, looks nice and clean
Looking good DaDokta, lovely work..... Regards Alan
Thanks for your nice comments, guys! Walter Greetings, Walter
This weekend i completed the right wing. Because of an error in the german instructions i had to disassemble the wing tip and apply the small frames twice.DaDokta attached the following image(s): Greetings, Walter
Walter Lovely build you have in the making. It's certainly a massive model. Hope the rest of the build goes well. Happy Modelling
Walter, Great work on the wings,good to see another Spitfire underway well done and keep sending Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Walter, That`s all looking clean and straight to me. Keep the updates coming and Happy Building. Regards delboy271155 Derek COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
The distinctive spitfire shape is really starting to show now, great work Walter, am enjoying your build.... Regards Alan
Thanks for the nice comments, guys!
Regards, WalterGreetings, Walter
Very nice Walter, coming along a treat.... Regards Alan
