Jase, Thank you for looking with the metal skin now in place I can feel the weight becoming more and more now a very solid plane. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
More great work Trev, keep em coming.... Regards Alan
I love your build, Trev!
Regards, WalterGreetings, Walter
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
Hi Trev its been a while since i checked out your build, its been great catching up! your work is truly fantastic Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Hi Walter, Sorry I missed your last post thank you for your comments , your build is looking great looking forward to your next update Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Dan Good to see your post to me and thank you for your comments, and for looking in, there will be a Spitfire update soon. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE: SPITFIRE. 140415. PACK 20. Pack 20 looks interesting we have the Propeller shaft, motor retainer, Allen screws, also upper wing plates 8/9/19 more nuts, screws, and washers. It looks to me like a lot of work on the metal skinning which I am feeling more confident about.  Propeller Shaft. Motor Retainer. Allen Screws. 5mm Nut.  Upper Wing Plate 4. Nails. Template.  Upper Wing Plate 8/10/13 Template. 5mm Screws/Nuts. M4 Washers.  2 Metal Plates. More Soon, Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE: SPITFIRE BUILD. 150415. Wing Plates. Just a small update on the work so far with the wing plates I have managed to secure upper wing plates without problems although I did start to run out of alignment towards the end of the wing, this I corrected by hand cutting a new plate and fitting in place. I still feel that I am learning on this build with the skinning and there's a lot more to do yet.  This picture shows the a cardboard template cut to size and ready to draw down onto the metal plate.   This picture shows sample shape ready to cut out.  This shows shape ready to cut out.  This shows shape ready to fit.  This shows plate fitted to wing ( the wing looks out of shape just the angle)   This shows the wings to date. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Very nice Trev, your panelling lookgs great
Hi Trev, Panels look spot on, very neat. Regards delboy271155 Derek COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
She really is coming along now Trev, great work once again.... Regards Alan
Greetings, WalterGreetings, Walter
This looks very nice Trev, love the paneling. Do you have any way of letting me know the thickness of the plating? I have a little aircraft project lined up and Id like to get some of around that thickness. Steve
Hi Davetwin, Thank you for your comments regarding the metal panelling, learning all the time. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Derek, Thank you Del your comments always appreciated. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Alan, Thanks Alan for looking, my next update will be the Propeller Shaft and motor retainer, looking forward to that. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Walter, Your comments are most welcome thank you. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Steve, Thank you for your comments, sent PM. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
PROPLLER ASSEMBLY: 230415. I have assemble the crown and brass screw to the base plate, that seems to be ok, but when I insert the Prop-shaft at the rear of the back plate and then tighten I end up with a small gap of about 1mm. Is this ok! or am I waiting for a small washer in the next issue, or do I need to correct it by reducing the thread on the brass nut.   Cardboard Packing.  Without the Cardboard packing I have movement. Thank you for looking. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev This is perfectly normal and as long as the crown and the brass shaft are of a tight fit then this is correctly fitted. Your build is coming along beautifully btw Spencer
Guest (11)
