21 Pages «<89101112>»
John Passmore Options
John Passmore
#181 Posted : 30 March 2015 04:37:22
delboy271155 wrote:
HI John, BigGrin
Very impressive. Cool
Looking really good and the encapsulated nuts for the stand are working well. I`ve built them into my sots build, but have yet to make the stand.
Had thought of the possibility of making a pivoting / swinging base to tilt the hull to make working easier. What do you think?
Keep up the good work. Cool Cool
Hi Derek
Thanks for looking in and the kind words...BigGrin
Yes, I think that installing the captive nuts was one of my better decisions early in the build...Cool The stand was a gradual development that came about as the work progressed. I personally would not consider a pivoting / swinging base unless there was a secure means of immobilisation whilst working on the ship...Cool
JohnP
John Passmore
#182 Posted : 30 March 2015 04:43:02
davetwin wrote:
Very Tidy looking build John, will look awesome when it's finished
Hi Dave
Thanks for looking in and the complements...BigGrin Dunno if it is going to look awesome at the finish, but I'll be happy with a "Fair to Modriato" seeing's this is my first build...Laugh Laugh
JohnP
John Passmore
#183 Posted : 30 March 2015 04:53:32
You've certainly moved her along in the past month John and a cracking job you are doing too.... Very nicely done indeed, well done that man....Cool Cool
Hi Alan
Thanks for looking in and complimentary comments...BigGrin
One thing I've noticed now the prow is fitted, my temporary work bench is going to be too small - especially when the bowsprit and yardarms are fitted...Blink
At the start of this little caper I thought 1200mm x 700mm would be eminently sufficient...Blink Blink
JohnP
John Passmore
#184 Posted : 30 May 2015 04:22:52
Hi Everyone
There was no Progress for April and the first couple of weeks of May 2015...Blink
However, the last 2 weeks of May were reasonably productive and Progress is reported below;
Working through Issues 40, 41, 42 and 43.....
- Completed gunwales and gun port linings Port side...Cool
- Installed Stern galleries both sides. Had a bit of bother with the little bamboo planks under the gallery window panels, but a little packing here and a little wood filler there had it fixed to satisfaction...Cool Cool
- Installed and painted forward bulkhead and Beak support...Cool
- Beak platform constructed and dry fitted, together with bowsprit ( which as supplied is warped at different angles in 2 different places) A new piece of 10mm dowel will be needed to replace it...Cool
- Beak platform garniture installed - some serious clamping required here to ensure it all stayed stuck where it was supposed to stick!...BigGrin BigGrin
- The last photo shows my build looking similar to step 22 of issue 43, for which I am quite happy about...BigGrin BigGrin
Happy building to All
Best regards
JohnP
John Passmore attached the following image(s):
#185 Posted : 30 May 2015 05:28:34
Hi JohnP, BigGrin
A credit to you, that looks very tidy WTG.
Cool Cool Cool Cool Cool Cool Cool
#186 Posted : 30 May 2015 08:13:25
BigGrin Looking great and a nice and tidy buildCool
#187 Posted : 30 May 2015 10:05:56
Great work John, shows your patience is really paying off. Well done, look forward to seeing more.....Cool Cool
AdamHall
#188 Posted : 02 June 2015 16:28:05
John,
Absolutely marvellous. The paint work and forward section are impressive and testament to the outstanding work you have put into the build.
BZ
Adam
#189 Posted : 02 June 2015 19:24:33
BigGrin Lovely work very clean and tidy keep the pics coming ThumpUp
John Passmore
#190 Posted : 03 June 2015 08:00:44
Hi Derek, Andy, Alan, Adam and Martyn
Thanks to you all for looking in and the nice comments.
The black paint doesn't look too flash in the pictures so I've just slapped on another coat...BigGrin BigGrin Cool
Just working on issue 44 now and found the third deck plates centre sections 85a&b
won't fit into the slots. Ribs 16, 20 and 21 seem to be 1.5mm to 2mm too far forward so I'm going to have to make some drastic mods to the slots - no worries, I can fix it...!Laugh Laugh
The forward and aft pairs of deck plates fit perfectly, so I don't know how the problem occurred...Confused
Best regards
JohnP
John Passmore
#191 Posted : 30 June 2015 09:37:10
Hi Everyone
Below is my progress for June 2015
Working through Issues 44, 45, and 46...BigGrin
Installed false cannon supports with additional buttresses...and 3rd deck support beams...BigGrin
Thought I'd be a Smart Alec and fit the 3rd deck planking before installing the deck plates...Blushing Poor decision that...Blushing as I had decided to use 0.5mm black rigging thread for the caulking. I had not considered the difficulties of achieving accurate continuity of the planking across the deck plate joints, nor the tangle created by all the loose ends of the rigging thread...Blushing The first deck plate finished up looking like a dog's breakfast...Blushing Blushing I've included a photo below...Blink
So I changed course and installed all the deck plates first - as per procedure - after a lot of messing about putting the first piece right...Blink BigGrin
I'm going to leave the deck without surface treatment as I prefer the scrubbed, bleached look I remember so well from my old seafaring days...BigGrin
For the nailed look I just used a HB pencil using a template I made to get a semblance of uniformity...Cool
Then it was time to install the forecastle deck and quarter deck. Once again I buttressed the false cannon supports. The top of the hull strakes under the foredeck were a little too much flared outwards, so with careful use of a long clamp was able to reduce that by 2mm each side. There is still a slight step of about 1mm each side which reduces level at about half way forward...Cool
All the mast holes line up nicely...Cool
The curved bulkhead strips at the back of the foredeck are 18mm above the deck and not 15mm as specified. I cut the strips at 41mm so the conclusion is, the rear edge of the deck is sitting 3mm too low. Can anyone advise if this will be a problem in future?...Confused
The quarterdeck dimension is spot on...BigGrin
I have up to Issue 68 under the bench so plenty of WIP in the offing...BigGrin
Happy building and best regards to All
JohnP
#192 Posted : 30 June 2015 09:46:38
BigGrin Stunning work John the decks look spot on ThumpUp
jonny7england
#193 Posted : 30 June 2015 09:46:40
Looking great John!! A big well done there...Wink ThumpUp
#194 Posted : 30 June 2015 10:17:05
Really fine work John, she is looking fantastic Cool
nightwisher
#195 Posted : 30 June 2015 13:20:06
Hello Australia we've actually got some sunshine in England,quick everyone outside before it rains again.Seriously though you're sovereign looks fantastic love the thread caulking, never been brave enough to try it myself. As for your 3mm difference in height you're middle deck doesn't look too low compared to the gunports.I can't really see where it comes from unless the forecastle deck is too high.I do seem to remember one of the uprights that sit behind the curved walls being to short and using an infill,did you force the deck down to meet it maybe?
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#196 Posted : 02 July 2015 00:41:09
Hi John, really lovely work you've done to date, looking fab.....Cool Cool Cool .. Will have a check on your height query and come back to you if I see any issues going forward with this....Cool Cool .. Keep the pics flowing....Cool Cool
John Passmore
#197 Posted : 09 July 2015 03:19:09
Hi Martyn, Jonny and Dave
Thanks for looking in and the nice compliments. Been crook with the flu for the past few days so no productivity since last posting...Blink
Can see some problems coming up when painting bulkheads, inside bulwarks etc that need to be masked at deck level. Masking tape will pull out caulking if I'm not careful...Blink Blink
JohnP
John Passmore
#198 Posted : 09 July 2015 03:42:16
Hi Nightwisher
Thanks for looking in and I've figured out how my little problem occurred...Blink
I have shaved too much off the top of the bamboo hull planks so the vertical at half way between 2nd & 3rd gunport is too low...Blushing
I had carefully followed a line from top of rib 2 over tops of ribs 5 & 6 to arrive at that point...Blink
Consequently, when the deck was trial fitted there was a small gap along the forward edge... I fixed that by sanding the platform at the top of the forward bulkhead! What I SHOULD have done is add another bamboo hull plank and then trim to compensate...Blushing
However - all is not lost - I have yet to plank the deck and have a plan of rectification forming - watch this space!...Laugh
JohnP
John Passmore
#199 Posted : 09 July 2015 03:52:17
Hi Alan
Thanks for looking in and the nice compliments...BigGrin
Yes the foredeck is sloping a little to steeply as can be seen in the different dimensions between the top of the 1st and 2nd gunports and edge of the deck...it's actually about 2mm. I will not be developing this area until I see what happens in relevant future issues...Cool
JohnP
Hans
#200 Posted : 09 July 2015 16:19:13
Lovely job there John. That caulking really show up the planking lines. Well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
This page was generated in 0.353 seconds.
