 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 04/04/2013 Posts: 89 Points: 270 Location: Stroud, Gloucestershire
thanks for the kind comments guys sometimes its a real struggle to get your head around things and you keep putting it off until its got to be done and then it sort of works out  - anyway enough waffle next step breach ropes and bits and then I can think about the upper decking thats a milestone!  Ant Current builds :
AL's HMS Surprise Model Shipyards HM Cutter Mermaid
Joined: 25/01/2010 Posts: 459 Points: 1,367 Location: Bridlington
antswain wrote:Hi all just a few more pics to show what im at - been working on upper deck furnishings,finishing launch and cannon blocks. Lower deck chain pumps built from scratch but have housed this on mahogany strips as fiddley. also on with masts and mast heads and bowsprit one question  - how do you fit the rings to the top of the cannons to take the thick restraining rope ca glue dosent seem to work keep falling off Ant Re-fit the rings to the top of the cannons, i drilled holes in and then put small eyes in them Regards
Rob
Bridlington.
Built Flying Scotsman (Train). Collecting HMS VICTORY
Thanks Rob managed it with CA glue in the end stuff I was using was old and therefore rubbish couple of pics of cannons found this real difficult so far and time consuming also another model ive had for ages just put frames together and deck - maybe I should have started this one first! regards Ant antswain attached the following image(s): Current builds :
Hi Ant, rigging the cannons is a fiddly and time consuming process but think you have done a great job with yours.. Very well done, looks great.... Regards Alan
thanks Alan ive stuck the big ropes down onto the deck now so not sticking up in the air looks more natural much happier with it gonna try the next six the other way round do the breach ropes first and the rigging after reckon this will be easier Ant Current builds :
just been doing a few bits - mast tops - wasn't happy with side windows to captains cabin so stripped out and redoing done the roofs above with hole punched card - cannons nearly done ordered ply for next deck plus did some planking on my other build HM Cutter Mermaid and started a painting! love being busy regards Ant antswain attached the following image(s): Current builds :
Lovely work Ant, coming along very nicely..... Regards Alan
have redone the side windows to the captains cabin and had to put in the window head right across because there was a gap here which can only be due to something I did wrong to the roofs  reasonably happier with the overall look though regards Ant antswain attached the following image(s): Current builds :
Looking good Ant....  .. Know it can be a pain having to re-do something but if you didn't correct something you are not happy with then it would annoy you even more every time you looked at your finished build.... Well done, coming along very nicely.... Regards Alan
getting her ready for the next deck which ive started Ant antswain attached the following image(s): Current builds :
Decking looking good Ant, nicely done..... Regards Alan
Joined: 02/04/2013 Posts: 174 Points: 534 Location: Bethlehem PA, USA
I thought the decking looked nice as well
Hi Ant. Wow your build is really coming along now and looks fantastic. Best regards. Mark
thanks for comments Alan,John and Mark think your right about the upper deck looks more natural than the lower. I used a light oak stain on the lower with some antique oil, the upper has just had one coat of antique oil rubbed in with a cloth before treenailing to see what it looked like. Cant change the lower deck now but live and learn  pics also show my other ship with first layer of planking almost complete regards all Ant antswain attached the following image(s): Current builds :
Joined: 08/01/2015 Posts: 68 Points: 178 Location: Holland
Hi Ant, great boat with some intricate work, keep the photos coming. Happy Modeling.........Terry On the bench. Cutty Sark 1869 Built. Mayflower 1609, Endeavor, 1768
Hi Ant, Very nice work, the deck looks great. Don't worry about the different shades as the upper deck would have been exposed to the weather a lot more Steve
thanks for kind comments Terry and Steve will post more pics soon as seem to be moving on with the build at a rate of knots at the moment! regards Ant Current builds :
shes coming together now all parts not glued as yet just put in place to see how she is regards Ant antswain attached the following image(s): Current builds :
Really looking the biz now Ant, lovely work being shown.... very well done... Regards Alan
Looking good mate. Just a little tip if you don't mind me saying, on your cannons the thicker rope you have rigged on them if you mix pva with water then brush it onto the rope, so it's soaked in it. Then you can add natural sag. Here's a link to my cannons. http://forum.model-space...s&m=22094#post22094
ChrisOn the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
