Disassembly Options
ALW
#1 Posted : 24 March 2015 11:40:30
Hello
Whats the best way to disassemble?
Thanks and regards.
#2 Posted : 24 March 2015 11:46:22
ALW wrote:
Hello
Thanks and regards.
Depends on which adhesive you used, but warm water applied by cotton buds so as not to over wet the wood should release most normal wood glues.
If you find you need to soak the whole structure, then you will need to keep the parts pressed flat while they dry or you will induce more warping.
ALW
#3 Posted : 24 March 2015 11:47:07
Thank you-I appreciate your advice.
Regards.
