4 Pages <1234>
My Build Diary of the Santisima Trinidad X-Section Options
#41 Posted : 18 March 2015 14:12:21
Hi Andy.
Looking realy nice, agree with alans comment about the contrast. of the wood. look forward to the next instalment IanCool Cool BigGrin
#42 Posted : 18 March 2015 22:34:52
BigGrin Thanks for looking in and your comments IanCool
#43 Posted : 18 March 2015 22:50:39
#44 Posted : 18 March 2015 23:06:08
BigGrin Hi Steve
Thanks for looking in and your comments, personally I have always thought the bare wood build would suit this build down to the ground to show off all those hardwoods and different colours. Although in the same way your painted build now gives others the chance to view both versions and decide what type of finish suits them.
#45 Posted : 19 April 2015 19:08:53
BigGrin Hi All
Its been a while but here is an update, I have carried on with the adding of decks and hull planks and now have reached the main deck area still some tidying to do and hull planking to add but coming along nicely. More soon.
der Gohfelder
#46 Posted : 19 April 2015 19:16:26
Hi!
A fantastic work you made, very well done!ThumpUp
Regards, Bernd
#47 Posted : 19 April 2015 20:30:03
Some more lovey work there Andy ThumpUp
#48 Posted : 19 April 2015 22:33:26
BigGrin Thanks for looking in and your comments both of youCool
#49 Posted : 19 April 2015 23:59:18
Very nice Andy, do love the colour you have chosen for those decks, certainly gives it that aged and well used look.... Drool Drool
#50 Posted : 20 April 2015 08:12:35
BigGrin Hi Alan
Thanks for looking in and your comments and thanks for the comments on the decks, I have been using Rustins dark teak wood dye on them then a couple of coats of matt varnish to seal them.
#51 Posted : 20 April 2015 22:13:39
BigGrin A little more done, top deck is on and one gunwale has been fitted. more soon.
#52 Posted : 21 April 2015 14:51:02
Hi Andy.
Realy looking superp. Love the contrat between the decks and the outside planking colours. How many cannons are included. Look forward to seeing more Ian.Cool Cool BigGrin
#53 Posted : 21 April 2015 17:39:40
#54 Posted : 21 April 2015 19:55:43
BigGrin Thank you both for looking in and your comments @ Ian there are 16 cannons all together 8 each side, They look slightly bigger than the ones provided for the full kit but have the cast metal carriages aswell.
AndyCool Cool
#55 Posted : 21 April 2015 20:09:25
BigGrin Hi All
The other gunwale has been added and the chainwale and belaying pin strips added along with some strip on the upper deck this finishes the majority of the hull build. The hull was sanded back and several coats of matt varnish sprayed on.
Next it was a start on the lower mast which has been tapered and the rubbing paunches and cheeks added. The thin strip provided for the rubbing paunches/cheeks is a little stiff so I recommend soaking in water before fitting in place.
Just a note on the pictures the ones before the mast picyures are of the hull after sanding but with the metal gun ports added to show how she will look and the ones aftre the masts are of the hull after 3 coats of matt varnish. More soon.
der Gohfelder
#56 Posted : 21 April 2015 20:39:40
Hi Andy!
Very nice, it´s looking great! I love the colours, is it the original delivered wood ?
Regards, Bernd
#57 Posted : 21 April 2015 20:48:58
BigGrin Hi Bernd
Thanks for looking in and your comments, all the wood on the outer hull is as supplied with the kit and just matt varnished, just the inner hull has been uniformly coated with Rustins dark teak wood stain to get that dirty used look I wanted.
#58 Posted : 22 April 2015 00:29:33
Stunning work Andy, looks absolutely fab....Love Love
#59 Posted : 22 April 2015 07:20:27
BigGrin Hi Alan thanks for looking in and your commentsCool
#60 Posted : 22 April 2015 14:10:53
Hi Andy.
Looking superp. Look forward to seeing more Ian.Cool Cool BigGrin
4 Pages <1234>
