4 Pages 123>»
SJW2511 Millenium Falcon Build Options
SJW2511
#1 Posted : 18 March 2015 12:29:52
Rank: Beginner Level 3
First post is going to be a very quick whizz through on what I have gotten to so far, the rest will be more in depth
Drilled holes in the gun ends
Other parts of the gun primed
Cockpit yokes
Everything in the cockpit comes black, so repainted everything from the seats the center console, amde stuff look worn where I could
Now this is where I decided to start repainting everything, I felt the factory colours were to unsubtle and garish and a bit toy like, so went out and purchased and air brush and compressor, my first time using an airbrush I hasten to add
Primered up the plating parts I had so far, using rattle can model primer
Then when that dried I started the preshading with the air brush, using Tamiya Rubber black, went over the areas I wanted to darken
Then mixed up a custom colour, 4 flat white to 1 deck tan
Then went over the parts with a top coat, I may even give it a bit more to make it more subtle.
Sprayed the panels that are meant to be grey. However before I started i put salt over parts of it
Why you ask, because it achieves a nice worn chipped look
The same panel before, I will do the red panel bits too but had to order some paint in the right colour
Also did some details on the cockpit tunnel, plenty more weather to come on these bits, Iv just had to order some more paint to do it
decided to crack open my weathering master kit and give it a go
painted the red areas on the turret
Found some etched brass decking online for the floor, dry brushed with silver and fitted some to the cockpit floor as a trial, but I think I may actually leave it there now.
Will do the big main floor panel in it when it arrives
decided to crack with some more of the weathering to the bits I already
Nuln oil applied in all the crevices
Then dry brushed with the main colour paint mix I had, then applied some powdered art pastels, how they stand at the moment
Looks a bit dark on those pics because of being taken against a white background
More accurate portrayal
#2 Posted : 18 March 2015 12:38:12
Good to see another Falcon build underway and congrat's on your first medal Cool
dandare
#3 Posted : 18 March 2015 12:41:13
Great start SJW2511, great addition to the cockpit floor looks perfect, some very nice weathering as well.
will be watching with great intrest
Dan
SJW2511
#4 Posted : 18 March 2015 12:46:37
Thanks guys, whats the deal with the medals then?
#5 Posted : 18 March 2015 13:11:55
Great start on the Falcon SJW, the cockpit looks fabulous as does the external weathering - well done!! Cool ThumpUp
The ModelSpace medal system is explained here:
http://forum.model-space...aspx?g=posts&t=2621
Kev BigGrin
#6 Posted : 18 March 2015 14:46:10
Really nice work so far Cool
Its good see another build, keep the updates coming ThumpUp
#7 Posted : 19 March 2015 16:01:38
Looking great.
I love the salt weathering technique.it looks really natural.
#8 Posted : 19 March 2015 19:07:44
BigGrin Top workCool
#9 Posted : 19 March 2015 23:10:41
Looking really good, nice Job
bruce3318
#10 Posted : 20 March 2015 00:08:59
That cockpit is sweet!! Can you share where you bought the flooring? That would kook amazing in the passenger areas! I may use the salt technique as well. I haven't received my shipment yet but so far this looks like an awesome kit!!
#11 Posted : 20 March 2015 09:17:02
Fantastic work ThumpUp
A novel idea to use half orange as a spray stand, but be careful as its surface can have a wax to it.
SJW2511
#12 Posted : 20 March 2015 22:59:39
Started on the interior fold floor, using the brass etched decking I recently purchased.
Masked up the area to be decked
Primed
Then I painted it black, but for some reason didnt get a pic of that.
Did purchased the Shapeways container grills however felt they were a bit chunky/clunky especially sat next to the brass etched stuff, so I made my own out of spare decking I had, I will finish these off with edging tomorrow when everything is dry.
Gave it a bit of a wash with black to "wear it"
Placed some of the other bits in there, obiously need to paint these yet
Will look better when i finish those center tiles off
#13 Posted : 21 March 2015 11:21:52
Some seriously nice work there SJ, she's looking fab... Drool Drool .. Keep those pics coming....
SJW2511
#14 Posted : 21 March 2015 14:00:15
Edged off the compartment hatch covers
bruce3318
#15 Posted : 21 March 2015 14:34:15
[quote=SJW2511]Started on the interior fold floor, using the brass etched decking I recently purchased.
Where did you purchase the brass etched deck? It really makes the cockpit and passenger are look great!!!!
SJW2511
#16 Posted : 21 March 2015 14:35:08
SJW2511
#17 Posted : 21 March 2015 16:58:42
made up the seat cushions, had to wire wool them as the weathering was way over the top, looked like someone had spilled oil all over them
Need to get some modelling putty to smooth the holes in the backs
#18 Posted : 21 March 2015 22:12:34
This looks really nice, you've donea great job.
I have been looking at a lot of different floor builds and thought I would like to do one myself as I can't really justify the cost of a 3D printed one.
I have started buying up some materials, just Evergreen Styrene, in preperation, hope to post soon BigGrin
SJW2511
#19 Posted : 22 March 2015 19:33:46
Made up the bunk bed bit
Wasnt happy with the panel join though, so used some filler glue, and some filler (not pictured)
Then sanded down and primed
Also primed these other bits
Then quickly decided wanted to respray the interior walls to add shading and also things like pastels stick to the paint better than the plastic
Primed up
Did some pre shading
Applied a medium grey
Nuln oil in these bits
Then highlighted the raised bits
Thats it for today
#20 Posted : 22 March 2015 23:11:20
SJ
what a brilliant job you are doing with this one.
That flooring was a real good find and looks top notch.
I can see you are getting some great fun from this build.
4 Pages 123>»
This page was generated in 0.179 seconds.
