Had a bash at them tonight and they are a nightmare! I managed to snap of the end of the solenoid so I had to glue it, just hoping it will hold. Did you use glue to hold them on and if so what glue did you use? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Joined: 27/06/2014 Posts: 393 Points: 1,104 Location: st austell
Steve have a closer look at my hose one bit is glued. Facebook-model maker
I bet it was the same one I snapped. It was the lowest one that comes off at an angle, the last of the 4 hoses to put on? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Steve279021 wrote:I bet it was the same one I snapped. It was the lowest one that comes off at an angle, the last of the 4 hoses to put on? That's the one hope it does not cause problems later. Facebook-model maker
Stage 32 done now. Left rear brakes and right side pod hoses done, after a bit of swearing!   Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looking good Steve I bet it was a lot is swearing lol Facebook-model maker
Looking good, Steve!
Actually i wanted to build this stage this evening. Reading all the comments about the hoses i wonder if i should watch tv with my wife instead :)
DaDoktaGreetings, Walter
Ian, your right, there was a lot! Dadokta, yes I'd wait until you're in a brave mood! Glad I got it out of the way although there is more to come I think. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Rank: Semi-Pro Level 2   Groups: Registered
davidyat here. I just finished the 8th packet and noticed you've done pack 9 and 10. Seeing the talk about putting on the hoses and snapping of plastic parts, and before I make the same mistake, are the hoses made out of rubber or soft plastic? If so, do you think soaking the ends of the tubes in hot water to soften them up make it easier to install and NOT have the prospect of snapping off plastic parts?
Dave
Ians idea of holding the ends against the radiator helped a bit. I think my problem was my modelling inexperience didn't help. Other people found it quite easy so it's probably more down to the individual. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 33 done now. Left rear hub/axle/brake assembly.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That's stage 34 and pack 10 done now. So at the halfway stage now.......  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
.......so that calls for a halfway stage parts put together!     that's it until pack 11 now. Might be tempted to start my mp4/23 whilst I'm waiting! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Nice pics, Steve! DaDokta Greetings, Walter
Thank you Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 11 here now.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
I also received Pack 11 - hope i can work on it this evening!
Greetings, WalterGreetings, Walter
You mean if the wife let's you!😁 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Just read back a few of your updates Steve, those hubs look amazing!
Although I have no interest in Formula 1 the more I see of these kits and the detail in them I keep thinking I should be adding one to my wants list
Stage 35 done now. Gearbox started on with the 2 outer cases.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
