6 Pages <1234>»
Gun Ports..a disscusion Options
benny
#21 Posted : 04 September 2010 20:06:33
hi riff-raff..not that i know of ..i am sure its single planked
cheers benny
Zeptrader
#22 Posted : 04 September 2010 20:10:55
I am pretty sure it single planked, so it gotta be good..arghhh!!!BigGrin
Mac
#23 Posted : 04 September 2010 20:14:35
riff-raff wrote:
I am confused Blink Blink Won't the ship be double planked ??
Unfortunatly no Riff Raff.
Hi guys just want to say how much I have enjoyed this interesting thread and how its been conducted without any desention. We need more threads like this on the forum.
Pam's shipyard is closed for now no more room!
captainalan
#24 Posted : 04 September 2010 20:19:23
Ive read the thread an 1 thing that keeps popping up is plans plans an more plans it would be great if we could have some 1 to 1 plans it would take all the hassle away i might right of to AL and ask if they could sell me the set i know its more expence but just might be worth it in the long run
#25 Posted : 04 September 2010 20:29:52
thomasmoult wrote:
Thanks Tomick, do you know when we will be starting the lower hull planking? And when we will get the next gun deck?
Thanks,
Tom
The next deck (upper) is currently set for issue 45/46 though this could yet change.
riff-raff
#26 Posted : 04 September 2010 20:39:27
Huh Huh Oh beggar - right first time then eh?Huh Huh
Built:
thomasmoult
#27 Posted : 04 September 2010 20:44:57
Thanks ever so much Tomick,
If you are going for the natural wood finish, consider double planking it with a thin veneer. Adds a lot of time to the build but allows for a little error on the first planks
Tom
riff-raff
#28 Posted : 04 September 2010 20:53:06
I am planning on painting mine but it's the gun ports that are worrying me. I think I maight make the edging for each port separatley, paint them & then insert them deep enough to show the rebate.
Lots of work but well worth it
Built:
thomasmoult
#29 Posted : 04 September 2010 20:59:02
They do seem quite daunting, especially how it is one of the most important parts of the build - any errors will be extremely difficult to conceal. From looking at the images from Tomick's build diary, I think the best way to cut them will be to drill the hole, file the hole bigger with a needle file, and then finally shape it with a flat file until the edges are looking good ready for the framing.
Tom
axle396
#30 Posted : 04 September 2010 23:10:48
Hi,
I have asked this question in a previous thread. Tomick replied that it will be "single planked overall and the bottom half skinned with a dark veneer".
Of course anyone is free to double plank if they wish. Personally I am trying to follow the build as done by Tomick. If mine turns out as good as his(he is after all a professional modelmaker)I will be more than happy.BigGrin
Jimmy L.
current builds : Lancaster 1/32 (Hachette)
Revell USS Kearsarge
Titanic Lifeboat
I started off with nothing and I've still got most of it left.
Zeptrader
#31 Posted : 04 September 2010 23:37:23
Jimmy
I agree 100% but he has to follow the official build, now if he wants to make changes that would move away from the official build he would have a few problems, at a guess.
I'm sure if you had to follow the build as per manufacturers instructions but felt additions or corrections needed to be made but were unable due to a contract it would be a little frustrating.
I'm still unsure as to the best way to achieve this problem, at least a problem that perhaps plans could otherwise help.
#32 Posted : 05 September 2010 09:36:28
I like Colin(zeptrader) have been thinking long and hard about the gunport linings,and other bits and pieces of the build,like the upgrading of the launch,anchor,cannons,in fact every part of the build so far,and the rebates in the gunports are now being considered.
Can you see now,why,al decided not to supply plans,the kit is aimed at the general public,not semi pro modelmakers,who could scratch build victory from a number of plans which are availiable.If al supplied plans,think of the newbees who would recoil in horror and think no way can I build that!!the way al have re-designed the way the build goe's is that it is possible and feasable for a member of the public to be confident enough to attempt the build with a little help from us,(experianced modelmakers)so getting back to the gunport rebates,I think the only way to successfully achieve this is to double plank,though I believe that the first layer will be 2mm thick,and the lining for the ports will be .05mm. or even 1mm.possible to leave a rebate of 1mm. not much,but enough I think to give the effect of a rebate.I agree a plan should be availiable for a small charge to those who want them,but I could then see the experianced boys picking more holes in al's attemps at building the Victory. -----------------me still thinkin' 'bout rebates if I come up with better idea then double planking I well let you know.
#33 Posted : 05 September 2010 10:02:43
I agree totally with karl the number of people i am sending detail packs to in both the uk and Germany that appear to be first time model builders or not made wooden before seems to be the majority.
In my personal view if an experienced wood modeler can find away of achieving the desired look without double planking that is the preference but as a first time wooden model maker i am happy to double plank with the guidance of the experienced modelers on the forum.
Zeptrader
#34 Posted : 05 September 2010 10:10:23
Yep some good points Karl, to be honest regarding the plans, if they could only supply a full size (model size) plan that could give us some ideas of measurements ect, that would be a start.
Ive seen a few ways of doing the gun port surrounds and making them rebated, some ideas I think would be unworkable due to positioning of the ports themselves.
Gun Port Framing (prior to planking) is a risky one, apart from the obvious of not knowing the position but then laying the planks in one length, you could cut around them but it would be hard to get a small lip in the rebate and also getting them laying across the hull inn one nice line if you went for smaller lengths around the gun ports.
If we could find the finished size of the gun ports that would help, starting the port of 12mm and adding some framing of 1mm gives us 10mm gun ports, this could then be attacked now.
Ive looked at tomicks diary and wonder if by not attaching the middle deck the planking could be started but only 4 planks, enough room to work inside the hull to add the siles and mantle and the 2 sides parts to form the surround, I think it would to almost impossible to work on the outside in to construct the framing...but
Ive seen a model and he talks of adding the framing with tweezers and a home made clamp to add them from the outside.
I think this problem of making the framing inside the gun ports is common with a lot of Victory models, ok the Jotika one is a little different but my thinking is this model is pretty good quality made harder only by receiving small bits at a time, the nature of part works I guess, I had this problem with the Bounty.
What does bother me and its only my thought is the comment by Tomick that the upper deck is scheduled for parts 45/46, and we are only on early 20's now, quite a long time to wait really.
I would prefer to single plank on my Victory, so finding a solution this way is preferably.
Anyway just my thought overnight, but maybe Tomick could find out for us what the finished size is of the gun ports, that would help a lot.
ArtfulBodger
#35 Posted : 05 September 2010 10:52:48
First of all a big thank you to Colin for raising this issue and in general the thread has continued without condescending comment. Horaah!!!
Most of us think that plans, even if supplied at additional expense, would be extremely helpful. I am sure DeAgostini could acheive this if sufficiently motivated. Equally I'm sure that most tiro builders are sufficiently mature not to be frightened off by such a concept. HMS Victory is a high aspiration of many builders and I for one believe that plans would help.
The earlier post re parallel lines and using a waterline marker seems a top tip. Obvious but only after someone has mentioned it.
Equally, some form of jig configuration to contruct the gun-port surround consistently is the way forward for me.
Finally, Colin and most of the guys/girls a big thank you for positive, constructive comment.
ArtfulBodger
Previous Build:
HMS. Bounty
Mike Turpin
#36 Posted : 05 September 2010 12:27:24
Reading Karl's post, I would agree that inexperienced modellers would find a scratch build daunting if all they had were the plans.
However, we can all take advantage of the step-by-step magazine instructions, Tomick's build and, of course, the forum. However, remembering that one picture is worth a thousand words, I'm sure everyone would benefit from a set of plans which help interpret the rest of the information and provide the opportunities to take measurements etc.
Speaking personally, if I had only had the limited Constructo set of instructions and the few badly defined pictures, I would never have got my HMS Halifax started. From square one I was referring to the plans supplied as an integral part of the kit.
This applies equally to those following the build as intended by DeAgostini and those more experienced who might feel the urge to modify with double planking etc etc. I would be more inclined to kit bash, if I could see where my kit was going!
Mike T
thomasmoult
#37 Posted : 05 September 2010 13:53:53
Mike T
I did read somewhere recently (cant remember where), that one of the reasons full-scale plans are not included was to stop people from not buying the issues once the plans were obtained, and sourcing the materials from elsewhere.
Dont think it was for the Victory, but it just shows you. I can without doubt say for certain that I don't think anyone on here would do that because we are all enjoying collecting the issues so much, so in that respect, there would be nothing to worry about. As has been said, the plans would aid each of us and as Mike said, would allow for improvements along the way not included in the magazines, something that can be frustrating when further along down the line, we realise there are bits that could have been improved if we knew what was coming and moreover if we had a set of plans to follow in addition to the magazine.
Just some thoughts to add to this ever interesting thread!
Tom
Zeptrader
#38 Posted : 05 September 2010 14:30:40
After fighting the garden this morning, and boy what is a fight I had more thought and ideas, nothing concrete but as its says on the tin IDEAS!
A lot of us have a number of book, Longridges book, McGowans and McKays, all of which have plans, that said we have positions of gunports on these plans.
We have seen on Tomicks build where the lower gun ports start from, the top of the first plank, also the side of the formers, so we have X and Y, we can then form a position to give us the 12mm (not actual size of the finished ports) but its a start.
If the plans as mentiomned above could be re sized and positioned we could then gauge the size and position of the other gun ports..yes or no?
Then and only then could the framing of the ports begin, I have found the build log of the prototype of Chucks Syren over at MSW, the one I started but never finished..(huh)
I think the pictures speak for themselves.
A paper template to show positions of gun ports.
A batten places as a marker for positioning, we have the first plank as that marker.
The sill are placed in.
Next is the lintels, again we need to know the final size of the gun ports.
Gun port sides are placed.
A little more is added, this is only for the Syren.
The area inside is painted red, with the first plank placed where the original baton was.
Planking starts.
Continuing upwards, just as we have seen in our build.
As you can see this would create the desired effect, superb I reckon.
And finally this is with the wales added and painted black.
Its well worth looking into this option, I forgot about it earlier and has been mentioned so this pictures may add some more comments, again we have 3 different sets of plans from those books mentioned above, BUT we need to get the correct size on scaling up the plans.
yorkieboy1
#39 Posted : 05 September 2010 15:24:25
Hi Colin
I have been mucking about all morning withthe gun port dilema and have done a mock of the victorys side and using tomicks measurements 12mm by 12mm I have cut down some planking to 2mm by 1mm and made some inserts which now makes the gun port 10mm by 10mm and it looks the business un fortunately my camera is poorly so I cant upload any photos do we know the muzzle width of the mock cannons I have tried the cannon 12Lb and the scale ie spot on with the inserts in place the gun hatch would have to be 10mm *10mm
thomasmoult
#40 Posted : 05 September 2010 15:51:06
I've got my Victory sitting there up to date with planking, and the ports marked out as per Tomick's directions. I am so tempted to get stuck in, but part of me is telling me to wait until the magazine comes on Wednesday BigGrin
Shall I do one and post a pic? LOL
Tom
6 Pages <1234>»
This page was generated in 0.201 seconds.
