Why screws? Options
Phil
#1 Posted : 13 March 2015 17:39:41
Just assembling the front wing and having a nightmare with it. So far, 5 rounded off screws which no longer turn. Am I missing something? Feel like it should be very easy.
Building the MP4/4!
dandare
#2 Posted : 13 March 2015 21:24:01
hi phil
try dipping the tip of the screw into washing up liquid before screwing in, it will help the screw cut into the plastic
Dan
Phil
#3 Posted : 13 March 2015 21:49:25
Thanks for the tip Dan, will try that the next time a screw is required!Cool
Building the MP4/4!
Ianerrid
#4 Posted : 07 April 2015 01:15:59
Rank: Beginner Level 3
What screwdriver did you use? I found the supplied one doesn't fit the screw heads well, hence I would think, your rounding problem. I use a specialist set of miniature screwdrivers and test before trying them on the precious model...
Phil
#5 Posted : 11 April 2015 16:36:14
Yes, I used the one provided with the kit, it seemed ok, maybe I will pick up an alternative and try the wax/washing up liquid method on the screws. Thanks for all the advice everyone!
Building the MP4/4!
Phil
#6 Posted : 12 April 2015 12:57:54
Ok so looking for an alternative but not entirely 100% on the size screwdriver I need, the guide in issue 2 says the screws are 1mm width? So do I need a 1mm cross screwdriver? Confused
Building the MP4/4!
#7 Posted : 12 April 2015 13:09:34
BigGrin Hi Phil
This is the set I bought off flea-bay works ok for me and they have magnetic tips.Any good precision screwdriver set will do the job.
http://www.ebay.co.uk/it...amp;hash=item58ae56b726
Hope this helps,
willie
#8 Posted : 12 April 2015 15:05:05
the trouble with x crosshead screws is no one says Philips is 60deg and pozie is 50deg angle and don't mix and a hard pointed screwdriver will take the edge of a screw if the wrong one is used, a dear screwdriver with a hard head sounds great but over tighten a screw and it will take of the the corners off and round the head, and use cheap screwdriver and you will damage the driver if you over tighten, I rather buy the cheap ones and save the screw
dandare
#9 Posted : 12 April 2015 18:16:57
arpurchase wrote:
BigGrin Hi Phil
Hope this helps,
stop pointing out these great things, makes me spend money LOL
dan
#10 Posted : 12 April 2015 20:34:21
BigGrin Glad to be of service Dan, another screw driver that comes in handy was the one provided with the Zero.Cool
Phil
#11 Posted : 14 April 2015 18:44:00
Excellent, will order this forthwith.
Building the MP4/4!
