 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
Having seen Tomicks recent post on cutting the gun ports I began to wonder a few things, NOT about the quality of the kit, NOT about the location of the gun port or even the cutting of the gun ports at this stage, but of the framing of the gun ports. After looking at the model show on the front page from DeAg they seem to show the framing as flush with the main hull and different type of wood, this has prompted me to ask a few question regarding the gun port lids, as I'm sure a lot will know the gun port lids when closed were flush with the hull, also as a lot are going to be doing here will want to paint them red. See below a few pictures as an example of what I'm trying to talk about. An AL build  this is a Jotika build, but shows the gun port framing inset and painted red  So I wonder if we can frame the gun ports prior to planking, this mean finding the position first, yes I know more work, but the end result if this is what you want would be more authentic? Again if any of use wanted the gun port lids closed for example, or like me would like to go for a more natural look then the choice of wood for the framing would look odd. Framing the gun ports have been done before on other models, again the Syren build (yes less gun ports) were framed prior to planking. I guess as the planks go down it could be done in conjunction, ie lower deck framing completed before those planks are fitted, then as the official build continues we moved up the hull and frame and follow. I hope this doesn't sound like a ramble, ITS NOT, and in no way is it questioning the offical kit..ITS NOT:) Its a simple case of looking ahead and seeing what could be done and what for me I would like to see in a finished model.
This is what I would like to achieve. Gun port linings finished much sooner than I was expecting (18 hours work). 72 gun ports lined in all (4 per hour). After a while it becomes easy. Initial fears of balancing a thin sliver of wood on a 1mm vertical edge soon faded when I discovered the three tricks - cut the wood a tiny fraction too big and then you can wedge it into position. Don’t use superglue, as you need to adjust each piece to ensure they are sunk in to the right depth and run parallel around all sides. Do the two vertical edges, let the glue dry, then do the top and bottom. If you try to do all sides at once while the glue is still wet, you end up knocking bits out of position (I still ended up with quite a few parts that dropped inside the hull never to see the light of day again…)
Hi Colin
Been thinking about this one for a while now and the best solution I can think of is double planking i.e. do the first planking cut out the gun ports and frame them, and then neatly double plank leaving a rabbit on the ports. Its not going to be easy to cut the ports out and frame them neatly so the double planking method will make it far easier
Joined: 13/10/2011 Posts: 851 Points: 2,628 Location: Leeds, Yorkshire
Morning Colin
It's the same problem coming up again, we just don't know enough about how the build will progress beyond the immediate issues. I'm not criticising Tomick's post in anyway but feel we should be told in the magazine how the gun ports will be finished so that we know how far to take the build at this stage. Again a set of plans for reference would have been useful. Then you could tell how the lining is going to be fitted etc.
I'm going to follow the build as far as possible because I'm painting the ship and therefore am not so worried about the appearance of different woods.
Mike T
I can see and understand where you are coming from on this one Colin, and thanks for raising the subject mate, as regarding the gun port frames and them being flush with the hull, I have seen them on other builds where they are slightly countersunk into the hull, if you get my drift? I shall be doing mine that way now that you have drawn my attention to the subject, and I shall try an source out some thinner wood for the framing..and of course, just above the gun ports the hull planking stands slightly prouder of the rest where the gun port covers have small chain or rope attached to it...perhaps an extra plank could be added to the hull above the gun ports to make irt look more authentic too...   Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
 Rank: Pro  Groups: Registered
Some excellent points raised by Colin, and I too agree with Mike that we need more forward planning. Sooner or later we'll end up doing something and then realising it could have been done much much better if we knew what was coming next.
I think the double planking idea is certainly worth considering.
One thing I've noticed is that, according to the Build Diary, the ports are 12mm square holes - once the frames have been added, they're going to be tiny!
Tom
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
Hi everyone, Just thought I would add my own thoughts on the subject I agree with Mike on the availability of some up front planning .In the video that came with issue one. Way on in the build it shows plans for the masts yards and rigging The planking and gunports in my book are the two biggest factors in the build get those wrong and you are in dead lumber and will have wasted a lot of money surely some where when this build was in its infancy plans would have been drawn why are we not privy to these I f you bought the kit in full from artisania plans would have been included as with any kit. I agree Tomick is doing a superb job but it would be even better if we had plans to look at and knew exactly what the complete kit consisted of
yorkieboy1 wrote:Hi everyone, Just thought I would add my own thoughts on the subject I agree with Mike on the availability of some up front planning .In the video that came with issue one. Way on in the build it shows plans for the masts yards and rigging The planking and gunports in my book are the two biggest factors in the build get those wrong and you are in dead lumber and will have wasted a lot of money surely some where when this build was in its infancy plans would have been drawn why are we not privy to these I f you bought the kit in full from artisania plans would have been included as with any kit. I agree Tomick is doing a superb job but it would be even better if we had plans to look at and knew exactly what the complete kit consisted of Agreed. Another thing I remember from the dvd that came with the first issue was that on the clip for cutting the gun ports, it was done when the whole of the upper planking was done, not just 6 planks. Not sure why the magazine is getting us to do it now I think I will wait until the upper planking is done before cutting them. One job at a time! Plus surely it will weaken the frame a little with only 6 planks done and then the ports cut? Just some thoughts. Tom
As mentioned in my build diary, the cutting of the gun ports has been broken down into three phases, the idea behind it being that you won't then have to cut all ports at once, its a long tedious task which needs care and patience, and remember safety first if you use a blade to cut them out, as an alternative method of removing the centre's, you could use a mini drill/dremel with a router bit, and then carefully file/cut-out the sides to the marked lines and finish, just be carefull the bit does not pop out of the port and across your model  , the main thing is to measure and check twice before you start drilling/cutting! As for their lining, at this stage I'm unsure when this will be done or what will be supplied for the task, but as soon as I know I'll post the info.
Thanks Tomick, do you know when we will be starting the lower hull planking? And when we will get the next gun deck?
Thanks, Tom
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
i was asking about this a couple of weeks ago..i wanted to find the size of the gun ports so i can build all the frames b4 we plank,maybe i wasnt clear enough but i wanted to set the port frames as we plank so when cut out the frames will be set back but nobody really entertained my question cheers benny
Where was your question regarding this Benny? can you link it here?
As in Tomicks build he mentioned 12mm square holes cut in the hull, and at a guess I would say the framing from another AL model pictured above I would say its a 1mm framing, so the gun ports would then be 11mm square when finished, just a guess.
I would also hazard a guess that the lining would appear when the whales are in place?
Interesting ideas being thrown around, if Tomick is not sure what comes next then we aint go a hope till it appears, maybe a small mock up is in order again:) maybe look at a few ideas.
hi colin i cant remember but i posted a question about..i wanted to know the size of the gun ports because i wanted to make a jig to get them all the same size my thoughts were to place the frames as we plank but me being me i wasnt clear with my thoughts..if the planking is a mil thick then the frames could sit behind the planking and they could be cut out as we go leaving a nicely positioned frame cheers benny
Zeptrader - as you are also going for the natural wood finish, I am curious to know whether you will be cutting the gun ports as per the magazine, or waiting until all of the upper hull is planked? Also, are you planning to replace the supplied frames (for whatever reason) and if so, with what type of wood?
Best wishes everyone, Tom
Yeah I see what your saying, but one thing keeps coming up and that's advance information, ie PLANS, plans for the location of the gun ports and then we could attempt the framing prior to planking.
i agree colin its about planning in advance and knowing what the next step is to do it right cheers benny
Tom Quote:as you are also going for the natural wood finish, I am curious to know whether you will be cutting the gun ports as per the magazine, No ideas yet tom, that's why I've made this thread, for me and people like you to bash some ideas around. Quote:waiting until all of the upper hull is planked? I dont think I will wait till the hull is fully planked, I do have an idea but really think I need to try it on a mock up first, to be honest as Tomick mentioned it could make the whole process of cutting the gun ports easier the official way as there is so many. Quote:Also, are you planning to replace the supplied frames (for whatever reason) and if so, with what type of wood? No idea again, sorry, to early yet for that, first I/we need to decide how rather than with what.
Benny, what we do know is we have to cut the gun ports, we know its gonna be 12mm square, so a jig/tool could be made in preparation for that, also doing the cutting is stages on thinking about it is a good thing, at least I think so.
I have this document on paper here with me and it reads as this -
Gunport surrounds are supplied with the kit but again I choose not to use then because 1. gunport lids were flush with the hull, with a frame on the INSIDE edge of the port. 2. it would be near impossible to lay wales in the correct position with cut through the gunports for and aft.
Agreed, and some good points coming in. This is turning into an interesting thread with lots of different ideas offered up for suggestions. Its threads like these that make this forum a pleasure to be a part of.
Tom
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
I am confused  Won't the ship be double planked ?? You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
