162 Pages «<154155156157158>»
#3101 Posted : 02 March 2015 23:49:41
Derek, Ant, thanks for your kind comments, truly appreciated.....Cool Cool
Gibbo
#3102 Posted : 03 March 2015 10:01:43
Very nice Alan, well worth the effort, and congratulations on the yellow.
Cheers
Paul
#3103 Posted : 03 March 2015 19:38:02
Cheers
Paul
Thanks Paul, appreciated as always.... Cool Cool
#3104 Posted : 05 March 2015 23:28:21
Issue 120 almost done and dusted... More bling to be painted for the prow and a doorway surround. Painted as per the instructions and given a coating of gloss varnish.. When dry the ornamentation was added to the prow and have to say am very pleased with how it all looks... The doorway surround has been stored to be fitted later...Cool Cool
Next task was to fit the fenders to either side of the hull. These pieces required a little bending to follow the hull contours, the trusty kettle and steam did the job very easily. Gave the fenders a coat of medium oak stain and a coat of varnish... Notches were then cut out using a 2mm fine square diamond file....Cool Cool .. Once happy these were then glued into position....Cool Cool
Final task on this issue was the doorway ladders. Instructions say to fit the first two rungs of 18mm, 1mm apart. I have done only one, if you fit two then you will find you do not have the room above the gun port to fit the gun port lid... Cut 8 rungs of 9mm rather than 7 as stated in the instructions...Cool Cool .. Once again, wasn't to keen on just leaving them natural wood so painted the rungs gold and gave a coat of matt varnish.... When dry, fitted all in place....Cool Cool .. Only have the ladder to fit on the other side, this will be done tomorrow evening then it's onto issue 121....Cool Cool .. Until then, happy building all...
#3105 Posted : 10 March 2015 08:10:37
BigGrin Lovely work Alan . I am also going to fit rope walks to the yards as they finish them off Cool
der Gohfelder
#3106 Posted : 10 March 2015 08:54:13
Hi Alan!
A very nice work, well done!
She is growing day by day, the finish is in sight!
Regards, Bernd
#3107 Posted : 10 March 2015 13:27:35
Hi Alan, BigGrin
More stunning detail painting, you must have patience by the bucket load.
WTG
#3108 Posted : 10 March 2015 14:31:57
HI Alan.
Looking superp. soon will need to press gang the crew. look forward to seeing more IanCool Cool BigGrin
#3109 Posted : 10 March 2015 23:56:28
Thanks Martyn, pleased to hear you are going to fit the footropes, think it just adds a nice finishing touch to the spars....Cool Cool
#3110 Posted : 10 March 2015 23:57:21
der Gohfelder wrote:
Hi Alan!
Regards, Bernd
Thanks Bernd, slowly getting there and can see in the distance the end is in sight..... Cool Cool
#3111 Posted : 10 March 2015 23:59:34
delboy271155 wrote:
Hi Alan, BigGrin
WTG
Thanks Derek, think in putting together these kits, just like your Lancaster, the one thing we all need is a great deal of patience....Blink Blink .. We know if we rush it, then it is likely to go all wrong....Cool Cool .. Thanks again.
#3112 Posted : 11 March 2015 00:00:25
ian smith wrote:
HI Alan.
Thanks Ian, always appreciate you looking in and commenting... Cool Cool
#3113 Posted : 11 March 2015 00:14:08
Hi guys, issue 121 finally finished this evening... Started with the making up of 6 cannon ball crates for the foredeck.. once constructed and to tone them down a little I applied a coat of light oak stain and matt varnish.. Cool .. Final task for this was to fill them with cannon balls, these are glued in place using again matt varnish and left to set...Cool Cool
Next, onto the 6 buckets to compliment the cannon ball crates, after painting again, (didn't like the first effort), I decided not to use the supplied handles and created my own using 0.15 thread. Buckets have all been packed with tissue, tissue was then covered in black paint and left to dry, this gives the appearance of gunpowder and I really like how it looks...Cool Cool
Cannon ball crates and buckets were then fitted to the foredeck...Cool Cool
Final task for this issue was the painting and fitting of the ornamentation for the other side of the prow, all done as described in the previous issue....Cool Cool
Next issue has us back on rigging so until then....Cool Cool
#3114 Posted : 11 March 2015 03:11:51
Nice work Alan
All your hard work really is showing especially with all these little details
mark 2
#3115 Posted : 11 March 2015 06:53:24
Hi Alan BigGrin .
I really like your idea of changing the bucket handles for rope ones and will do that for mine when I get to that stage if ok with you.
Your tissue paper looks fantastic to and really sets it off Love Drool Cool .
Fantastic work as all ways.
Best regards.
#3116 Posted : 13 March 2015 23:40:33
davetwin wrote:
Nice work Alan
Thanks Dave, it's the little details that go to make a build that little bit extra special....Cool Cool .. Thanks again for taking the time to look in...
#3117 Posted : 13 March 2015 23:42:12
mark 2 wrote:
Hi Alan BigGrin .
Best regards.
Hi Mark, thanks for your kind comments, appreciated as always. Cool Cool.. You are very welcome to use any of the ideas from my build, be my guest....Cool Cool
#3118 Posted : 18 March 2015 11:26:22
BigGrin Stunning work as always Alan ThumpUp The buckets look bril Cool
#3119 Posted : 18 March 2015 23:46:32
Thanks Martyn, the buckets didn't look great with the handles supplied, or at least I didn't think so. Rope handles just fit the period better I believe....Cool Cool .. Thanks again...
#3120 Posted : 22 March 2015 09:45:28
Hi Alan, BigGrin
As good as ever, WTG.
Another option for gunpowder is crushed graphite from pencils.
(Carpenters pencils are best, more graphite by the inch)
Used it on a dio I did a while ago, but the method used on yours gives another way to achieve the same end result.
Good to see and share different methods.
Keep up the good work.
Cool Cool Cool
This page was generated in 0.363 seconds.
