Sinbad Options
Sinbad
#1 Posted : 09 March 2015 22:31:05
Turquoise Medal: Turquoise Medal for model making know-how contribution
Firstly, this is by no means a complaint or a cry for help,it's an observation.I am amazed at how much I have to build up the lower frames at the bow for planking.
It does say in the book that some shims or packing may be required and from past experience I know that nothing is perfect on this build.
The main culprits seem to be frames 12 & 13. I've had to build them up by at least the thickness of a plank (2mm).Before anyone asks if I have these frames pushed down enough the answer is yes.
There was a time I would have got discouraged by this but I have since learned to adapt and press on.
#2 Posted : 10 March 2015 00:25:32
its well documented that some building up is required if you look at the many build diaries.
Sinbad
#3 Posted : 10 March 2015 12:18:53
jase wrote:
its well docomeented that some building up is required if you look at the many build diaries.
If you read my comment Jase you would see that I was and am well aware of this. But this much???
#4 Posted : 27 June 2015 11:55:10
If your well aware of it how can you be suprised by how much, as it is debated at Lenght?? Not sure what your trying to to say or do???
